Help deciding what TPS to use. HALL effect vs reg.
Old 02-28-2017, 03:41 PM
B_Swapped93's Avatar
Default Help deciding what TPS to use. HALL effect vs reg.
This has been bugging me from the strat, this car will only be a "highway runner" like what you'd see in those 1320 street race videos. Running 88a mounts turbo k20 90mm ktuned tb/ITM. I've been leaning towards the HALL effect tps from ktuned. it's $220-ish CAD, next option is their billet V2 which is a fair bit cheaper. My only concern is I've head of there busting on some ppl, last thing I need is to buy stuff twice. My concearn with the HALL effect is you've got to set it in K-pro, I have the V1 of that, i'm assuming it's not "that hard". I'd really like some input as to what others are using in their "track cars", i'm ruling out he D/B adapter, as removing the TPS is beyond frustrating to me, and I don't have time to go to the junkyard with my current job. That plus it looks like I have to re-pin the plug or something too.
Old 02-28-2017, 05:03 PM
been there done that
doood's Avatar
Default Re: Help deciding what TPS to use. HALL effect vs reg.
It's hit or miss with either of those two options. My friend's hall effect has been working fine for a long time while some people get a dud right out of the box. Calibrating them in kpro is fool proof and works fine. I've never manually calibrated a tps on the tb and had no issues.
I'm using a mustang tps on my kinslers as they're much more reliable and stupid cheap.
Old 02-28-2017, 05:49 PM
That's what worried me, there was something about the v2 owners getting a discount when the hall effect one came out. I'm trying to keep this as plug and play as possible, but I assume the mustang one is a 3 wire and all you have to do is cut and match the wires to the engine harness, nothing else.
Old 03-01-2017, 08:14 AM
pogeeboy27's Avatar
No issues for me, however my car is primarily a daily driven street car with only a couple track days and has softer mounts than what you are running. Calibrating the TPS in Kpro is easy.
Old 03-01-2017, 08:28 AM
Should specify, this car may only see 2,300 km's in my ownership AT most, I just need it to work for that time period with out any hick ups. I watched a video on how to calibrate it, that won't be an issue from what I can see. Basically do I have a better chance with the HALL one than I do their billet v2, in my research I haven't seen almost no negativity about the hall effect one.
Pogeeboy27 are you using the HALL or just the stock k series tps? didn't say in your post.
Old 03-01-2017, 02:06 PM
pogeeboy27's Avatar
Sorry about that. I'm using the K-Tuned hall effect sensor.
Old 03-01-2017, 03:16 PM
redGSRguy's Avatar
My Ktuned V2 crapped out on me after 15 months. It is just a plastic TPS with a shiny shell.
I switched to an Acuity and have not had issues with it yet. I have heard the v3 is hit or miss. As long as you get it from a dealer you should be fine since I think they come with a 1 year warranty.
Old 03-02-2017, 02:44 PM
Thank you everybody who responded, my initial thought was the ktuned HALL effect tps, i'm going to stick with that. seems the most plug and play/safest bet.
Old 03-02-2017, 04:27 PM
stayontrack's Avatar
ACUITY is Hall Effect also, with good reviews
xotic_crx
10-13-2015 07:17 AM
4piston
03-14-2014 11:06 AM
strikerflo
65
08-22-2008 09:14 AM
Quick Reply: Help deciding what TPS to use. HALL effect vs reg.
