Ktuned electric water pump, plumbing Q's k20a2. - Honda-Tech
Old 03-17-2017, 03:38 AM   #1
B_Swapped93's Avatar
Default Ktuned electric water pump, plumbing Q's k20a2.
I'm not too concerned about wiring it, I was gong to run it off the fuel pump signal wire/relay?. But one glaring question comes up, what happens to the "2nd" rad hose there's 2 ports on the plate/kit one for the PCV and then one to the pump. That's it, i'll be running a SF tucked rad with -16 AN so i'd assume I could just "cap" the 2nd outlet on the rad, and just run 1 rad hose? The 2nd issue is with filler neck, i'm using the ktuned one but there's still the port for the hose that would have ran down to the stat housing do need a special(new filler neck). I guess I can't run a thermostat with this set up either.
B_Swapped93 is offline   Reply With Quote
Old 03-17-2017, 04:57 AM   #2
stayontrack's Avatar
Default Re: Ktuned electric water pump, plumbing Q's k20a2.
i think there is two outlets on water pump, it goes to lower radiator hose.
ktuned website shows the plug for the filler neck on their site
stayontrack is offline   Reply With Quote
Old 03-17-2017, 03:29 PM   #3
been there done that
doood's Avatar
Top hose coming out of the top housing into the top of the radiator. Bottom hose out I the bottom radiator to the pump then to the water plate. Block off any extra ports you're not using. You can run an inline thermostat if you want but I don't see the point unless street car. Even then.....keep it simple.
How I have mine so far:
doood is offline   Reply With Quote
Old 03-17-2017, 03:44 PM   #4
Thanks, I contacted ktuned, where I got confused is I thought the water pump had just 1 inlet(made no sense). So the other port on the plate is just an extra, if you wanted the hose in that position. Yours is in an RSX right? did you wire it the same way one would wire an aftermarket fuel pump?
The one i'm looking to purchase is the "complete k-series alternator water plate kit for 699.99 USD. it comes with 2 ports, vs the "race" plate one
Thanks a lot for the pic.
Old 03-17-2017, 03:58 PM   #5
doood's Avatar
I personally recommend the tractuff plate like mine. Much better quality and the pump it comes with is way better. The other smaller -8 port is for the pcv. Run it to a catch can or block it off. I have an eg. It will be wired to a relay to a switch panel so I can turn the pump on and off as needed.
Old 03-18-2017, 02:09 PM   #6
njn63's Avatar
This how I would do it as well.
We run the water pump/fans after shutting the car off on our drag cars because it cools the engine off quicker between rounds.
njn63 is offline   Reply With Quote
Old 03-18-2017, 03:10 PM   #7
Where are you guys "feeding/drawing" the power from, is there a 8awg from the battery to switch/relay then to the pump? and what rad as you using that has a -12 AN port, SF/RYWIRE all state -16 or 1.25. I have no choice but to run a tucked rad due to the size of the big ktuned manifold+90mm tb/ 3.5'' intercooler piping taking up most of the left side.
Old 03-19-2017, 09:09 AM   #8
doood's Avatar
I'm having a dedicated relay/fuse panel made. Just need to make sure your wiring and relays can handle it. You can use a -12 to -16 fitting to connect the lines.
Old 03-19-2017, 03:26 PM   #9
I'll see what AWG the wires off the pump are and match it, that's what I figured i'd have to do doesn't seems too bad. You just capped off the hose from the oil cooler right?
Old 03-19-2017, 03:43 PM   #10
doood's Avatar
I'm using a k24a4 block so it never had those lines. You can delete them.
Old 03-19-2017, 05:07 PM   #11
tony_2018's Avatar
Why not use the thermostat fan switch to enable it automatically? When the fan turns on it will turn on/off the pump.
tony_2018 is offline   Reply With Quote
Old 03-20-2017, 03:24 PM   #12
Quote:
you can get the k24 oil filter holder that doesnt use the oil cooler instead of capping off.
Old 03-20-2017, 04:42 PM   #13
njn63's Avatar
My examples are all old school v8 drag cars so I don't have any relevant advice.
Quote:
I'd be concerned with hot spots further away from the thermostat switch.
Old 03-20-2017, 04:44 PM   #14
Quote:
I'd prefer to keep it, just cause I have no plans to run an aftermarket cooler. I'll see how hard/much $ it would be to switch over. I'm assuming it's part of the old pcv system, and that "air" is being pushed/sucked through it when hooked up in the stock configuration. Thanks
Old 03-20-2017, 07:13 PM   #15
#016 PartNo: 90015-PH1-013 HOLDER, OIL FILTER Price: $3.95 Assembly Qnty: 1
you would only need this part that holds the oil filter so there is no sandwich plate
Old 03-21-2017, 03:35 AM   #16
Would need a frost plug for the line that runs to the block, don't suppose it's the same number as the heater hose frost plug.
Old 03-22-2017, 08:16 AM   #17
Marky Mark's Avatar
What are people with the Type S oil cooler doing after converting to the electric water pump? The hose that use to go to the OEM pump housing can just be capped off?
Marky Mark is offline   Reply With Quote
Kswap parts list EG/EK GoldieWang K Series 17 08-21-2016 11:27 PM
Coolant problem with 2002 civic ex 98hatchhonda Honda Civic (2001 - 2005) 1 05-14-2016 05:46 PM
rad hoses for h22 civic EG krazycivic4u Honda Prelude 3 05-19-2006 01:05 PM
proper radiator / surge tank / overflow tank setup? long rambling :/ Buttcrack All Motor / Naturally Aspirated 2 04-27-2006 07:28 PM
2.2 Vtec Prelude Gots hot with Vtec...please help. mattsteadz All Motor / Naturally Aspirated 3 01-29-2005 03:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
