Kswap need some help/info - Honda-Tech
Old 11-09-2016, 10:55 AM   #1
Default Kswap need some help/info
Did some searching around and I couldn't find some answers so I'm hoping you guys can answer them for me. Let me start by telling you guys the set up.
K20a2 w/ EP3 5 speed
TSX Cams
50* VTC
RBC IM
Things to come:
12:5-1 high comp pistons
custom fuel set up (obviously)
Port and Polish
Goal HP: ~250whp
Now on to the questions. This swap is going into my EF and I'm having trouble deciding on an ECU. Yes I know Kpro is the best and that's where I plan on going once I get the money. But I've heard that people use JDM ECUs to bypass the immobilized. I was wondering if the JDM PRC or PRD ECUs will work with a 5 speed? Also would I be able to run the stock K20a2 with the TSX cams and RBC on the factory JDM ECU without running into tuning problems? I just need an ECU to run the car for a month or two so I can save up for kpro and a tune but I don't want to ruin the motor. I do still have the stock K20a2 cams and cam gears if I have to put those back in. Thanks in advance. Any tips and info on what may help is welcome.
Also is there a difference between the a2 and K20a3 rocker assembly? I know the VTEC engages differently and my motor came without a rocker assembly. I have a k20a3 one from a previous motor and I want to know if I can run that instead without losing power or messing with the VTEC.
Evo9GSR is offline   Reply With Quote
Old 11-13-2016, 10:39 AM   #2
Default Re: Kswap need some help/info
http://hondavert.ru/k-pro/
Works perfect. Much cheaper than hondata.
janiscrulzz is offline   Reply With Quote
Old 11-23-2016, 09:43 PM   #3
thanks. Anyone running it In the US? I have some questions but all the info I find is in what looks like Russian lol
Old 11-27-2016, 11:39 PM   #4
Quote:
its 100% hondata copy. I am running it in my kswap ek and have no problem. Use kmanager same as hondata. I can get the board for you.
Old 12-11-2016, 03:28 PM   #5
What's your price?
Old 12-12-2016, 08:43 AM   #6
What's your price?
300 usd +shipping and install board in ecu can do most electrics. I did my for 20euro. What ecu u are running?
Old 12-12-2016, 01:18 PM   #7
Use Hondata KPro... you will be much happier in the long run. That Russian copy/hack doesn't work as advertised and you will have NO product support if you have issues.
JRCivic1 is offline   Reply With Quote
Old 01-22-2017, 07:46 AM   #8
GoldieWang's Avatar
Quote:
x2......And if you are running cams in it and not tuned for the difference, It may run Hell it may idle but the AFR wont be spot on. Not saying that you'll torch the engine and destroy it but me personally when I make a change that significant it gets a few logs and a provision to the tune.
GoldieWang is offline   Reply With Quote
Old 01-22-2017, 10:49 PM   #9
Thanks guys. I've decided to run the PRC ECU and just save if for kpro. From what I've read I shouldn't have issues running the jdm k20a ecu on a k20a2
06+ k24a2 with K20 vts boostedb16a K Series 6 04-28-2016 06:36 PM
K swap no start?. hctim00 K Series 3 01-07-2016 04:27 PM
k20a2 crx waywayej K Series 4 12-11-2014 09:18 AM
K-Pro Vs. Haltech Ecu YaBoiTHiZZ Acura RSX DC5 & Honda Civic EP3 12 08-19-2010 06:08 AM
here is what fits what rick_rabies K Series 5 02-25-2010 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
