K24a4 Piston rings without removing engine
Old 06-08-2015, 11:24 AM
Paul Kane's Avatar
Default K24a4 Piston rings without removing engine
Good day all,
So last night my engine decided to take a poop on me and cylinder 3 (not sure if cyl. 3 but reading left-right 3rd one down) does not fire anymore. Tried new sparks and that temp fix no longer works. My car burns oil ever 300-400 miles so I know the piston ring is shot. I am assuming that this cylinder loss compression last night and will need to have the rings replaced. I was wondering if anyone has tried this or if even possible to replace the rings without removing the engine. Mark the timing chain, take the head off, remove the oil pan, loosen the rods and then turn the crank to push each piston up giving me access to change the rings. Please let me know, any suggestions help!
Old 06-08-2015, 12:38 PM
m_shake's Avatar
Default Re: K24a4 Piston rings without removing engine
Yes you can. That's what we do at the dealerships with all these V6 and 4cyl piston ring issues honda is having.
Old 06-08-2015, 05:49 PM
KseriesKing425's Avatar
Pull the head leave the block in the motor ...
butch1175
02-12-2013 06:06 PM
forsakenriceboy86
11-29-2009 09:08 PM
a1320honda
01-10-2008 05:18 PM
gunner6696
22
01-12-2006 06:18 PM
J T*
02-22-2002 03:05 AM
Quick Reply: K24a4 Piston rings without removing engine
