1995 k swap eg trouble
Old 04-06-2013, 09:38 AM
Bruduh69's Avatar
Default 1995 k swap eg trouble
i have a 1995 honda civic eg that ran great until now. Recently i have replaced the oil, coolant and tested ect sensor, thermostat. but the car ran rough on start up like it was running of a couple cylinders, this morning i went out and started it, this time started nice crisp i was surprised. so i drove it around the block and came home and pulled it in the drive way and low low idle. this then shut my car off cause it didnt want to stay running. i then started it again this time i had to give it gas to start and then once it started it was blowing out a bunch of smoke. can someone help me with this its getting really frustrating.
Old 04-06-2013, 03:30 PM
slowDB7's Avatar
Default Re: 1995 k swap eg trouble
what color was the smoke?
Old 04-07-2013, 01:54 AM
Joe McCarthy's Avatar
When you drained the oil did you look closely to see if there was any metallic sheen to it?
If its idling at a lower than normal speed and doesn't want to keep running that's a good indication you've got a higher than normal friction situation, so DO NOT start it again because you'll just hurt it more than you have already. Take the oil pan off and do an inspection on all the rod bearings. When you drain the oil examine it to see if there's any metal in it. I'm not talking about big chunks, it'll be really small particles that make it look shiny in bright light.
That's the best I can do with such limited information.
Old 04-07-2013, 01:14 PM
I serve phở for my babies
ohsnapzafingcu's Avatar
you guys think it could be his IACV? mine gives me trouble sometimes. his could be gunked up, the K is a little different than the b
Old 04-07-2013, 05:08 PM
Its fairly rare for them to get gunked up to the point they don't work if they're being used constantly, but its a possibility and easy to fix. His is obviously still working to some degree or it wouldn't idle at all.
Old 04-08-2013, 02:11 AM
Bruduh69's Avatar
Hey guys I recently took the car to a garage just didn't want to deal with it anymore. I'll let you know what was wrong when I get word.
Chev
18
02-16-2019 09:04 AM
Jose_eg
07-10-2018 09:40 AM
Jose_eg
07-09-2018 02:25 PM
TheLukeMartinez
12-01-2013 05:29 AM
Headlessmunky
03-25-2011 01:43 PM
Quick Reply: 1995 k swap eg trouble
