K24 QUESTIONS
K24 QUESTIONS
Im doing a k24a1 / k20z1 swap on my 05 rsx,(blew my k20z1 setup), down shifted wrong gear.
i bought a k24a1 long block (CR-V) , i wanted a k24a2 block (TSX ENGINE) only for the 200hp vs 160hp (CR-V). now what is the difference between these two engine? (BLOCK ONLY, NOT ALL THE COMPUTER CONTROLLED STUFF) is the only thing higher compression..if i were to buy a set of TSX pistons and throw them on there, would that make it "TSX" engine...also if i can throw some aftermarket high compression pistons on my k24A1 engine how high can i go on pumped gas...12:1 ?? 13:1 ?? and will i hit my valves.. sorry so long..
Re: K24 QUESTIONS
im wondering the same thing, and at the same stage as well although i didnt blow anything up , i wanted to know as well if that HP diffrence is such a deficet to begin with that maybe i should hold out for a TSX block over a Crv with higher compression pistons and rings.
Re: K24 QUESTIONS
my 05 rsx started out as a base model... i put in the k20z1 set up after blowin the base model (160HP automatic) with NOs (80 dry shot), i switched it over to the K20z1 set up (210 hp).... it was like night and day the power difference. now since i blew up my k20z1 and switchin out to k24a1 bottom and z1 head, im thinking i should have gotten the tsx motor, but then i was thinking if i switch out the k24a1 (cr-v motor) pistons to a higher compression will it be better then a stock k24a2 tsx block... because a crv is (160hp) and tsx (200hp)...if its going to be like my old base model rsx VS type s rsx... (160 to 210hp) the power difference is very very noticeable... so for sure im going to switch out pistons but idk to what...so now im stuck
Re: K24 QUESTIONS
I believe the k24a2(tsx) block is the only block you can use without doing any mods to it. the problem you have with the other k24 block is that you have to change out the pistons to have enough piston to valve clearance. the tsx motor is 10.5:1 compression stock but putting a k20 head that has smaller combustion chambers you should be around 11.5:1 compression, which is a good set up without having to spend the money and labor on after market pistons..
Re: K24 QUESTIONS
Re: K24 QUESTIONS
im thinking of just buying a set of TSX pistons and Throwin it into my K24A1(CR-V) engine set up wit the k20z1 head..(((can i just throw in the TSX pistons in the CR-V block??))) im looking for naturally aspired set up..im tired of cops and stuff.. so no turbo..or no greddy set up either(even though it has a CARB #). im thinking of just a RBC manifold, V2 AEM intake, RC 550 injectors, Kpro, exhaust and a lil head porting and gasket matching... and by passing the coolant line in the throttle body area.. so i guess just simple bolt ons.. do u think u can give me any pointers...
Re: K24 QUESTIONS
its hard to find an A1 or A2 block id be happy with just the block and crank.. then i do the rest.
Re: K24 QUESTIONS
Well if you plan you plan to leave it stock internally the k24a2 is the best bet. It has stronger rods, higher comp pistons, a better crank and it has piston squirters which keep the pistons cooler. If you already have a k24a1 you can definitely throw TSX pistons in to gain some more compression (I have a set for sale if interested, lol). The k24a1 block is the only block you do not need to modify your type-s oil pump for whereas the A4 and A2 need the pump to be notched. Also the k24a1/a2 will accept the type-s head with no issues while the k24a4 you will need to swap out the pistons to avoid piston to valve contact. If you have any other questions feel free to ask as I am currently building a k24a2 for my DC5 and a k20/k24a1 long block to sell.
Re: K24 QUESTIONS
with a k24a1 block you can get 09 tsx piston which would be a direct replacement of the a1 piston. 04-08 tsx piston would also need tsx rod.
Re: K24 QUESTIONS
so i just need to order TSX pistons from an '09 car.they will fit on my k24A1 (2003 Honda CR-V)....thanks..i was about to order '06 ones..lol..so now i know to get '09 model...im also wondering about the "FAMOUS" RBC intake manifold..found a new OEM one for like $185..part number 17100-RRB-A00, does this sound right?? i know that i need the adaptor plate and cut off the coolant passage...(SO DO I JUST GET ONE FROM A 2006 HONDA SI??)
when swapping out pistons......to clean the bore you just hit it wit a can of brake spray??? and clean??? then when installin the new pistons do i first put a lite coat of oil on the cylinder walls then slide the piston back in?
Re: K24 QUESTIONS
Re: K24 QUESTIONS
with the 09 tsx you don't need to mod the rod for them to fit. with 06 you will need to mod the small end of the rod out 1mm for the bigger piston pin. i would get the block hone. install the piston with Assembly lube on the ring compression tool and on the cylinder walls, the intake manifold you want is the 06-up civic si intake manifold. with an a2 head you will need to cut off the water passage tho.
for the RBC intake i will but putting it on a K20Z1 Head ('05-'06 type s RSX)..
will it be the same as an A2 head?? also needing to cut the water passage and it will fit on there nicely?
Re: K24 QUESTIONS
i believe all of the rsx type s head are the same. just the newer si's are different... you can easily line up a type s intake manifold gasket on to the manifold and cut the water passage out where the gasket ends
Re: K24 QUESTIONS
so im puttin the engine back together..k24 with k20z1 head.. i am having trouble putting the timing chain..im using the k24 timing chain with the k24 chain rails..am i using the right set up..i cant push back the tensioner that much to bolt it in..what am i doin wrong???
Re: K24 QUESTIONS
THANK U TO EVERYONE WHO HELPED ME OUT....i think i got it now..almost done!!!!! here r some pics.... k24a1 block, TSX pistons with k20z1 head...
Re: K24 QUESTIONS
I NEED UR GUYS HELP!!!!!!
so i put my engine in..i started it up..then i noticed it leakin coolant?? on this k24A1 to K20z1 head setup was there a port up top i 4got to block or what do u guys think it is???
http://www.youtube.com/watch?v=acfoT0-mAJk
http://www.youtube.com/watch?v=4MgsR8Nc_jI
what did i do wrong
what did i do wrong
Re: K24 QUESTIONS
Innes
11-15-2007 02:12 PM
