k24 HELP !! VTEC actvator or ECU Problem ? - Honda-Tech
Old 01-24-2017, 05:04 PM   #1
Default k24 HELP !! VTEC actvator or ECU Problem ?
Hi to make a long story short I own a 2003 CRV 2.4L Ex AT Have Codes P0300, P0301 , P0302, P0304 , P0341 and sometimes P0344 and sometimes P1259 car bogs down and won't go over 2700 rmp once I get the p0341 or p0344 or P1259 until I reset it. I replaced spark plugs no help, tested and replaced vetch solenoid and cleaned filter , tested vtec oil control solenoid and cleaned filter , replaced cam sensor , also replaced timing chain and guides and tensioner. none of this helped please help me find out what's wrong
thanks in advance
mouses911 is offline   Reply With Quote
Old 01-30-2017, 10:24 AM   #2
ekb16's Avatar
Default Re: k24 HELP !! VTEC actvator or ECU Problem ?
how is your oil level
ekb16 is offline   Reply With Quote
Old 01-30-2017, 06:45 PM   #3
think I found the problem front oil screen was damaged allowing no filter to the other components even though I cleaned all the other oil screens. the front main screen behind the power steering pump was damaged allowing no filter of the oil and damaged the CVT actuator or clogged oil passages. the screen on the vtec solenoid was bad too but cleaned it and replaced the whole unit also clean the screen on the oil solenoid and kept seeing metal fragments so either it's a bad CVT actuator or clogged oil passages to the cam CVT actuator. will know more this weekend
99 civic ex with jdm 96 spec b18c itr - codes please help 710dabber Hybrid / Engine Swaps 3 12-27-2015 10:42 AM
Need help with a P1259 Engine Code KiDSoL Honda Civic / Del Sol (1992 - 2000) 0 03-17-2015 05:30 PM
P0325 and P1259 codes related? j894 Honda Accord (1990 - 2002) 4 12-01-2013 02:52 PM
hesitation, vtec malf code1259 dwr1977 Tech / Misc 2 01-28-2012 07:04 AM
2003 EP3 not running right!!! HELP!!! PLEASE!!! rlgraham69 Acura RSX DC5 & Honda Civic EP3 23 03-18-2010 02:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
