k20a2 original key and transponder
I'm in the midst of doing all my homework on swapping my 96 EK DX to a rsx type s k20a2 and trans. Now for the most part I understand what I'll need but forgive me if this is a dumb question but I've tried google search before posting and my works firewall blocks me from searching on the forum. SO PLZ DONT FLAME ME TO DEATH! I've been doing some research and found that for the k20a2 I would need the original key and transponder if using the original ecu. I've also read that I could use the kpro ecu instead. I prefer the kpro so I can tune for the I/H/E but would love some opinions based on your experiences. Its my first honda swap so plz know that I am eager to learn as much as possible and apprecieate any and all help.
Thanks
Thanks
Re: k20a2 original key and transponder
Also just found this immobilizer Bypass. With this would I just use my ek's original key and ignition
http://k-tuned.3dcartstores.com/Immo...ass_p_131.html
I did some more research and found this on modified, about placing the k series in the ek...
You need the ECU, key and transponder that match your new K engine. However, Hondata does have a reflashed RSX, RSX Type-S or Civic Si ECU available with dyno-proven results. It also has a fully programmable version based on the RSX Type-S ECU that gives you control of ignition, fuel, i-VTEC, idle, redline, nitrous control, boost and more. If you want the Hondata, the best way to go is the fully programmable unit because it's the only one that can disable the error codes associated with missing emission controls. Be sure to budget at least $400 to $500 for dyno tuning. Hondata will also sell you a brand-new ECU if you're moving from a non-Hondata compatible ECU (Accord, Element, CR-V) to a programmable or reflashable unit. Hasport has ECUs with the immobilizer removed, but you'll be expected to provide full documentation (including VIN numbers) of where you obtained your swap engine. If you source your own ECU, you'll need the matching VIN number as well or a new ECU receipt. The purchaser's info will be shared with law enforcement upon request.
Read more: http://www.modified.com/tech/0407scc...#ixzz38F3qA3BQ
hope this helps.
hope this helps.
And if you do go this route, please, please do some research on this product before you dump $200.00 on it than find out it will not work!
hope this helps.
hope this helps.
Thanks for the advice and help!
