K swap no start?.
K swap no start?.
Hey guys just finished my k swap. It's a k20a3 with just basic bolt ons and a rbc manifold. The car is a 94 hatch. I'm using the stock ep3 wire harness and ecu. Using k tuned conversion harness and immobilizer bypass. I try to start it and it gets fuel and spark. But no start. Plug in scan tool and no codes. The check engine light flashes 5 times after trying to start. I know for kpro ecus that means it's detecting knock? Any info from where to go from here would be great. Thanks
Re: K swap no start?.
Update. It's getting fuel to the rail but injectors are not firing tested one injector clip and got nothing for volts. Where to go from here?
When I first tried to start my car after my swap, I had the same issue. My injectors were sitting for a while so they were stuck. Soaking the tips in gas loosened them back up. I also connected them directly to the battery to get them to open and close.
