Integra k swap awd
Old 12-16-2015, 10:54 PM
estefi357's Avatar
Default Integra k swap awd
I've been doing a lot of research about this project I'm going to post pics of the parts and procedures u need to do very simple not going into a lot of detail. The pics I'm going to post are not the parts I'm using and it's up to what name brands or knock offs u want to use. (It's just the best way to explain the parts to use)
The kswap is self explanatory but the real challenge is the awd conversion. In one of the pics it shows the placement of the crv hub holders and the other shows the custom caliper bracket.
I have read that u can use rsx shifter box and cables with the crv awd tranny (correct me if I'm wrong)
The fuel tank needs to relocated u can customize(check out the pic with the fuel cell) u can place it on ur trunk or u can cut ur spare tire well so u can relocate the fuel cell under there. You can weld the oem sending unit to the fuel cell that way ur fuel guage will keep working.
Depending on what chassis u are using will have to find a way to mount the crv diff.
I'm also going to post a pic of a chart of the axles idk it might help.
Old 12-17-2015, 06:43 AM
redGSRguy's Avatar
Default Re: Integra k swap awd
Shouldn't be too difficult. BC Performance out in Nevada has a few AWD setups. Their EG runs 8s!
flatblackhatch
03-28-2009 10:36 AM
dosemark_1
01-26-2006 11:20 PM
sonek
07-15-2005 04:44 AM
Quick Reply: Integra k swap awd
