here is what fits what
I'm not Rick!
i see a need for alot of consolidated info. at least its a try.
i will update this continously with changes and updates i learn.
if im wrong please correct me and i can add or change. this should be a sticky, neither h-t nor k20a.org has a condensed sticky of what fits what.
this will help all the noobs such as myself
all exhaust manifolds will fit all K series heads
rsx type s intake manifold is preferred -rbc from an accord type r or the k20z3 which is in an si in the us can be uesd on k24 heads but if u put it on a rsx type s head u need to cut off a coolant port on the manifold that isnt on the rsx s head u wanna stay away from an accord or other manifolds
only some TBs will fit some manifolds but they make adapters,
the rbc requires an adapter plate to fit MOST
throttle bodies. It depends what throttle body you want.
all oil pans will fit all K series if you use the corresponding oil pump and,
you could use any oil pan, bolts differ on k20a2 from k24's a few are larger
oil pump use k20a2 one and k20a2 oil pump chain, erl's makes a modified s2000 pump
k24a4 timing chain is needed and timing chain cover
k20a2 water pump housing and oil sandwich plate is needed it has a port that uses coolant to cool the engine oil or u could use an external one and keep your k24 water pump housing......ps if using k20a2 plate and w. housing youll need it to get a hole drilled out near the oil filter, you see on the site lower down
hybrid racing also has ablock off for p.steering and ac which helps relocate the altenator for hood clearance on crx's and ef hatchs
all valve covers fit all K series heads
a k20 head will only fit on the k24a1 and k24a4
some k24 series pistons some fit all k24s with the right rods. valve to piston clearence is the issue.
if your going k20 k24 swap k24a4 pistons wont work u need to get tsx k24a2 pistons or crv k24a1 pistons or aftermarket
all K series trannies will fit all Kseries motors...there is even a high $ adapter to adapt a K series tranny to an s2000 motor.
for k series swaps into eks you can use RSX base or S axles but use B series outer hubs
for egs you can use the RSX base 32mm axless straight up. but if you hae a type S tranny 36mm you need type S inner hub or type S axle and B series outer. http://www.k20a.org/forum/showthread.php?t=1594
you can use a Dseries throttle cable, but not a gsr cable. EP3 workx also...i think
KPROYou can use kpro with the k24a2. You need to use a different throttle body (i used a type S) because you need to convert from drive by wire (electronic controlled throttle body). You also need to use a type s engine harness. This makes it compatible with kpro. engine harness is different its drive by wire electronic stuff that is not needed.
KPRO doesnt work with automatic trannies.
doc_ecu on k20a.org can modify k series ecus to disable immobalizer and etc to get your car started...no need for kpro..
to put a k24 in an eg you need...
1-throttle body
2-type S harness and charge harness...or repin the tsx harness.
3-crv passenger mount
1-throttle body
Re: here is what fits what
for one the piston statement - if your going k20 k24 swap k24a4 pistons wont work u need to get tsx k24a2 pistons or crv k24a1 pistons or aftermarket
second rsx type s intake manifold is preferred -rbc from an accord type r or the k20z3 which is in an si in the us can be uesd on k24 heads but if u put it on a rsx type s head u need to cut off a coolant port on the manifold that isnt on the rsx s head u wanna stay away from an accord or other manifolds
oil pump use k20a2 or k20z3 one and coresponding oil pump chain, erl's makes a modified s2000 pump
also if u go with a with the different pumps ull need the baffle and youll need to plug a hole that will make u loose oil pressure if not done ..... check out my post for it a guy postdpics of howts done
that was off the top of my head
any other info will be here if u want to use it to make your list http://74.53.88.82/~hybri10/?p=420
LVCURVS
07-21-2007 11:43 PM
DonReggeaton
01-22-2007 09:30 PM
3vilMonkey!
04-19-2005 08:42 PM
