Can I put a k24 head on a k20a3 block if so what would I need - Honda-Tech
Old 12-29-2016, 03:41 PM   #1
Default Can I put a k24 head on a k20a3 block if so what would I need
Just looking for some info if I could put a k24 head on a k20a3 block If so what would I need
Em199civicsi is offline   Reply With Quote
Old 12-30-2016, 08:02 AM   #2
ALL MOTOR EM2's Avatar
Default Re: Can I put a k24 head on a k20a3 block if so what would I need
what k24 head? a k24a2 head? yes but you will have piston to valve interference because it was not meant for a k24a2 or k20a2 or k20z3 head.
your best bang for the buck would be to turbo or supercharge your k20a3 300whp is about the limit on those rods
ALL MOTOR EM2 is offline   Reply With Quote
Old 12-30-2016, 01:10 PM   #3
i have a ep3 right now with a k20z3 in it what could I do with that bad boy
Old 12-31-2016, 05:42 AM   #4
GoldieWang's Avatar
You could do a quick spooling turbo setup with that k20z3. Im doing a tr3030r (modified garrett gt3076r) with a sidewinder manifold on a k20a2. Should spool up in the low 4000's and breathe good enough for just under 500whp.
Only thing I am doing to the engine as for supporting mods is valve springs and retainers.
GoldieWang is offline   Reply With Quote
Best K series head/block combo for boost Wrenching--Time K Series 1 10-20-2016 02:36 AM
K20 block and K24 head grimey civic Tech / Misc 2 08-07-2008 09:15 PM
K20a3 head on a k24a4 block? trakwhore Acura RSX DC5 & Honda Civic EP3 3 04-03-2008 01:48 PM
can the k20z3 head match up with a k24a4 block? Prototype115 Honda Civic (2006 - 2015) 13 09-29-2007 10:35 AM
k24a2?? VS. k20a2?? EJ1_228 Tech / Misc 1 08-27-2007 07:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
