Another axle question.
I have a 94 integra in my shop with a K20a w/6sp. I need a (as in one) drivers side axle for it. Can I use a RSX-s or does it have to be custom setup? I did a short search and would rather not go through the trouble of joining K20a.org just to search. I'm only after the inboard joint. The stub the inserts into the differential broke off the inboard joint.
edit; it looks like if I buy a RSX-s axle I can just take it apart and use the inboard part, if I'm correct you need to have the b-series outter joint on a RSX-s axle. Is this correct?
MikeTV
01-04-2005 06:17 PM
