97 civic kswap will not start please help!!!
Old 04-15-2015, 06:41 AM
Bsracing78's Avatar
Default 97 civic kswap will not start please help!!!
i just finished my kswap into a 1997 civic ex. here is the info on the swap
2004 accord block
2004 rsx type s head
2004 rsx type s trans
2004 rsx type s wire harness
hasport ekk2 mount kit
hasport conversion harness
kpro
when i turn the ignition on the main relay clicks and the check engine light comes on for a few seconds and turns off. the car will crank over just fine. the problem is there is no fuel pressure. the fuel pump is good. the problem is the computer is not grounding the pin on the main relay that triggers the fuel pump to run. i am stumped on this one. i think maybe i have not installed the hasport conversion harness correctly, but i don't know.
any thoughts?
Old 04-15-2015, 10:33 AM
H-T Premium Sponsor
Hasport's Avatar
Default Re: 97 civic kswap will not start please help!!!
give us a call 602-470-0065
ask for Brian in wiring
Old 04-15-2015, 12:26 PM
GoldieWang's Avatar
In kpro have you made sure to turn off the immobilizer? I know that can be a duh question but I just wanna make sure you knew to do it. I mean I was so excited to finish my swap that I forgot to wire my immobilizer delete and spent probably two hours problem solving and even resoldered the main relay.
Old 04-16-2015, 04:21 AM
Bsracing78's Avatar
thank you for the feedback. i double checked the immovilizer. i had it turned off.
i had a long conversation with brian at hasport last night. he was very helpful!!! unfortunately it looks like i have a bad computer. everything is wired correctly and should be working, however the computer will not turn on the ground that activates the fuel pump. long story short i now have a direction to go moving forward with the project. thanks very much to hasport for their excellent customer service!!!
Old 04-16-2015, 07:55 AM
GoldieWang's Avatar
dang man. How far are you from lee county VA? maybe you could try my ecu to ensure its a damaged ecu
B_Swapped93
K Series
03-08-2017 03:43 PM
rturner
K Series
18
10-30-2015 06:49 AM
whitehf
09-12-2011 12:03 PM
SOHConthis
01-22-2011 08:28 AM
Quick Reply: 97 civic kswap will not start please help!!!
