wanting to build fast all oem sohc
Re: wanting to build fast all oem sohc
a vtech SOHC isnt as good as a non Vtech DOHC. think you'll just waste money trying to beef up a single cam. why not just build a N/A dual cam. still a sleeper in the right chassis
Probably true but with a DOHC built the right way will give you up to 240's no boost i believe . for the money you'd be spending on a single cam you might as well invest in the dual if you're looking for the most power for the money without putting turbo or supercharger. check this N/A build out --> HERE he essentially did what you want to do but with a DOHC. it's alot to go through but worth it if you're planning on doing something as well as this guy did.
no replacement for displacement. (well depending on a single cam you decide to rebuild lol )
NewRacer
05-15-2003 08:31 PM
