won't go into any gear
My civic won't go into any gear when it's on but when I shut it off it goes into any gear ...please help. I forgot to mention it has a b20b swap
re: won't go into any gear
Also sounds like it has a rod knock or something is rattling it's started making the noise rite before the transmission started having this problem
Re: won't go into any gear
probably going to have to take the tranny out and inspect clutch, flywheel, throw-out bearing etc. maybe something is loose or broken? what happens if you start the car while its already in 1st?
I personally wouldn't want to try that. If I ruled out the exterior stuff (check your hydraulic lines, connections etc) you know you're going to have to the clutch and check it out anyway... ?
There is a good chance your flywheel bolts are loose... this would account for the noise just before the clutch/transmission issues. Pull the transmission and inspect the clutch/flywheel package. You will find your problem there.
nus_dogg
03-25-2009 07:53 PM
civicnightmare
21
02-07-2004 12:00 AM
