Wiring Trouble Shooting Help - CRX / B16a / EG Chassis Harness / GSR Engine Harness
Old 01-30-2011, 04:53 PM
kevinoneill's Avatar
Default Wiring Trouble Shooting Help - CRX / B16a / EG Chassis Harness / GSR Engine Harness
My setup:
1989 CRX HF w/ an EG Chassis Harness (I know this is a little odd, but that's what its got)
OBD-0 B16a, came out of my previous running car
OBD-1 GSR Engine Harness - had to cut alot of plugs to match the OBD-0 Engine
OBD-1 P72 ECU, Chrome
OBD-1 Dizzy
The issue:
Won't start
- Turns over, seems like no spark. Turning the key doesn't work right now, but I jumped the starter and it turns over strong. Turning the key does prime the pump, but nothing after that.
- I have fuel pressure (i know for 2 reasons, first b/c i have a fuel gage on my fuel filter between 40-60psi if i remember right, and 2nd b/c i didn't tighten down the fuel rail and i sprayed about a gallon of fuel all over the garage )
I have had to do quite bit of re-witing etc... i followed the attached diagram of the harness, soldered the wires.
Used a wall mounted MAP
Wiring Harness Details
- Used a wall mounted MAP, had to swap plugs on one of 2 plugs going to it
- Cut the injector plugs and use the obd-0 ones
- knock not used
- changed plugs on the coolant switch or sensor at the back of the motor
- extended the IACV, didn't reach for some reason
- changed plug for reverse
- VSS not hooked up yet, different style
- IAB plug not used
- resistor box added, followed a tutorial to find the wires from the inject, spliced them into the resistor box and joined up other ends of them
- obd-0 engine had 2 1-wire o2 sensors, bought a new header and used 1 4-wire o2
- had to swap the plug on the vtec solenoid and sensor? might of been just one of them
- the other plugs all hooked up right
I need some advice as to where to start trouble shooting, and how to go about. This is my first swap, learned a lot so far. Open to suggestions.
I bought the dizzy, ecu, and harness to complete the swap - so can't guarantee 100% they work, i assume they are good.
Old 01-30-2011, 08:58 PM
Default Re: Wiring Trouble Shooting Help - CRX / B16a / EG Chassis Harness / GSR Engine Harne
Maybe someone has some good links for trouble shooting. I found a good link to check if a dizzy is getting power/signal, i'll check that.
What else could I look at?
Old 01-31-2011, 02:55 PM
civic_loner22's Avatar
i would have converted the motor to obd1 not the harness just sayn
Old 01-31-2011, 06:08 PM
Agreed, too bad I bought the car with the OBD-1 chassis harness.
Trouble shooting suggestions?
Old 02-02-2011, 01:59 PM
bump dump!
Old 02-03-2011, 02:45 AM
ive done the whole eg chasis wiring obd1 swap into my old ef. for me it was just more pratical a junkyard near by had alot of crashed eg and all my obd0 plug kept breaking from being so old.. also i swap in a obd1 motor started first time. if i were you i check all your wires again check ground. and even consider going str8 obd1
Old 02-10-2011, 06:55 AM
will be checking the dizzy for power this weekend, double checking wiring...
any suggestions?
toolbox21
04-30-2012 01:35 AM
MidShipCivic
28
09-19-2007 10:01 PM
1dopesi
10-06-2005 11:37 AM
91teg
09-01-2004 06:06 PM
Quick Reply: Wiring Trouble Shooting Help - CRX / B16a / EG Chassis Harness / GSR Engine Harness
