will dx axles work with the b18c1 swap
just need to know becuase hmotors online sells just the motor ecu and tranny than they sell the complete change over do i need to whole change over or can i use the my axles and shift linkage
Re: will dx axles work with the b18c1 swap (tonesdef)
Get the whole complete swap motor, tranny, ecu, axles, wiring harness...everything. Your dx stuff won't work. You could always just order that stuff motor, ecu and tranny and look for that other stuff local. (What ever is the cheapest)
Re: will dx axles work with the b18c1 swap (b20_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20_EK »</TD></TR><TR><TD CLASS="quote">your shift linkages will be short, I think you use the ones for an integra or from an Si</TD></TR></TABLE>
yep, 94+ B series shift linkage will work as well.
EFing8
07-15-2003 02:16 PM
