01 GSR in REX Help with crank position sensor.
Old 11-17-2004, 09:19 PM
CRXLST's Avatar
Default 01 GSR in REX Help with crank position sensor.
I have a skunk 2 manifold B16 comuter and B16 dizzy. I know one of my dizzys are good. Do I need 2 change some pins in the ECU for the crank position sensor???
Old 11-18-2004, 07:45 AM
CRXLST's Avatar
Default Re: 01 GSR in REX Help with crank position sensor. (CRXLST)
bump
Old 11-18-2004, 11:46 AM
Katman's Avatar
I assume you going to stay OBD-0 with your crx right? or are you planning to convert to OBD1?
If you stay OBD0 you need to get a hold of a 89-91 B16A distributor.
If going OBD1 its best to getta hold of an OBD1 B-series dizzy.
Doing this will alleviate you of crank sensor issues, because on US OBD2 vehicles/engines, the crank sensor is located on the oil pump rather than inside the dizzy (which OBD-0/1 all have).
Old 11-18-2004, 07:47 PM
CRXLST's Avatar
Default Re: 01 GSR in REX Help with crank position sensor. (K@man)
I am using a B16a dizzy. Really I have put 2 on it and both throw the code. So anymore thoughts???
Old 11-19-2004, 06:06 AM
91civicDXdude's Avatar
just a quick heads up...
you can use any distributor as long as its the correct OBD generation. It will fit into the cam slot and physically plug in, but you will have to modify the mounting legs to get it to bolt up.
I have a d16a6 distributor on my b18a1, my friend has a d16a6 distributor on his b16a
Old 11-19-2004, 09:57 AM
locash's Avatar
Katman - Actually, he was referring to the crankshaft position sensor, which is inside the distributor on all B/D series engines, regardless of obd type. The crankshaft fluctuation sensor is mounted on the oil pump assembly..
akinas-crx
10-28-2011 06:00 PM
project91crxsi
08-05-2010 11:26 AM
lsvtecEM1
04-19-2010 05:57 PM
kbouchard1092
01-18-2007 05:23 PM
Quick Reply: 01 GSR in REX Help with crank position sensor.
