For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable? - Honda-Tech
Old 08-23-2008, 11:35 AM   #1
Banned
Default For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable?
For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable? What do I need to get my car running? I'm thinking about picking up a K24 from this guy that has a totalled TSX. Any information would be greatly appreciated. Thanks!
OneSimpleHatch is offline   Reply With Quote
Old 08-23-2008, 12:21 PM   #2
ITR-EKcoupe's Avatar
Default Re: For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable? (OneSimpl
pretty sure you can throw a K20 head on there and do the frankenstine and get rid of the drive by wire. correct me if im wrong.
ITR-EKcoupe is offline   Reply With Quote
Old 08-23-2008, 05:14 PM   #3
ekb16's Avatar
k20a.org is ur new best friend
ekb16 is offline   Reply With Quote
Old 08-27-2008, 12:43 PM   #4
Banned
Quote:
I've heard that I can just switch to a K20 Throttle Body, but wanted to confirm this.
And again, I'm referring to a TSX K24 already with 11:1 compression. Just do some headwork and call it good. I dunno.
Old 08-27-2008, 12:43 PM   #5
Banned
Default Re: (ekb16)
Quote:
Got it. Thanks.
Old 08-27-2008, 01:45 PM   #6
k24_dc5's Avatar
Default Re: (OneSimpleHatch)
swap to a RSX throttle body and KPRO and you are good to go
k24_dc5 is offline   Reply With Quote
Old 08-28-2008, 10:58 AM   #7
Turbowa's Avatar
Like stated above, Just swap out the TB for one off of a RSX w/ a regular throttle cable and run k-pro. Problem solved. There is no need to swap the whole head.
Turbowa is offline   Reply With Quote
Old 08-28-2008, 11:38 PM   #8
Sanji
toyomatt84's Avatar
In order to run a K20 throttle body, you'll need an adapter plate. To do as direct of a swap as possible, get an Accord ('02 - '04) throttle body. They use similar intake manifold designs and are cable driven.
toyomatt84 is offline   Reply With Quote
Old 08-29-2008, 09:29 AM   #9
Banned
Default Re: (toyomatt84)
Quote:
Quote:
Quote:
Thanks guys! That's some good info there!
Old 08-29-2008, 01:10 PM   #10
oneslowstd's Avatar
you can also use 06 accord throttle body those arent drive by wire poo!
oneslowstd is offline   Reply With Quote
Old 08-29-2008, 08:16 PM   #11
Banned
Default Re: (oneslowstd)
Quote:
Good stuff thanks for the continuous info guys!
Old 08-30-2008, 03:46 PM   #12
oneslowstd's Avatar
good luck
NEED HELP !! swap k24a2 (tsx) in 02 crv fardoche250 Honda Element & CR-V 4 10-25-2016 11:30 AM
K24a2 into rsx vacuum lines Dillonkennedy00 K Series 0 08-04-2015 09:03 AM
TSX transmission LSD? sirchuzo Acura TSX 2 03-22-2014 07:30 PM
k24 in 1991 civic sedan tacosandbeans Honda CRX / EF Civic (1988 - 1991) 7 10-29-2010 01:01 PM
drive by wire conversion cmdr430 Acura TSX 2 12-05-2004 09:49 AM
Tags
2006, adapter, body, cable, cali, drive, engine, k20, k24, make, manifold, plate, swap, throttle, tsx, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
