TPS sensor volt test - Honda-Tech
Old 01-16-2009, 11:59 PM   #1
dohcem1's Avatar
Default TPS sensor volt test
How exactly do you test for the volt on the tps? does the car has to be on ? i dont exactly get where on the sensor can you test for the volt? thanks.
dohcem1 is offline   Reply With Quote
Old 01-18-2009, 01:14 AM   #2
dohcem1's Avatar
Default Re: TPS sensor volt test
please advise?
Old 01-20-2009, 02:05 PM   #3
i believe its the red wire that goes to the TPS. Car does not have to be on but ignition does. And I believe it should read as close to 0.5 v as possible. If its over, it bad.
chicows18 is offline   Reply With Quote
Old 01-20-2009, 09:05 PM   #4
dohcem1's Avatar
Well yeh I know about the .5 v and stuff I just meant how do I physically test for it. SO i basically have to strip the red wire that goes to the TPS sensor and put a multimeter and read the voltage?
Old 02-03-2009, 12:55 AM   #5
SINISTR's Avatar
do you have a multimeter?
SINISTR is offline   Reply With Quote
Old 02-03-2009, 02:25 PM   #6
dohcem1's Avatar
yes i do, I just don't know where I could physically test the volt...
Old 02-03-2009, 06:45 PM   #7
LA_HONDAS's Avatar
stick it in the seals
LA_HONDAS is offline   Reply With Quote
Old 02-03-2009, 11:02 PM   #8
dohcem1's Avatar
...seals? can you clarify that? Sorry for being such a newb but i really do not know. Thanks
Old 02-04-2009, 12:42 AM   #9
NUISANCE's Avatar
NUISANCE is offline   Reply With Quote
Old 02-04-2009, 08:55 AM   #10
dohcem1's Avatar
Wow PERFECT PERFECT thank you for the link. Exactly what I was looking for. One last question, the OP of that thread saids to set it at .5 volt (and so did chicows18 earlier post), but i thought I saw somewhere that saids set to .45 volts is best? well does it even make a difference? Just curious. Thanks
Old 02-05-2009, 04:31 AM   #11
NUISANCE's Avatar
I set it at .5, not sure if it makes a difference but seems to be what it is supposed to be at.
Old 02-05-2009, 11:29 PM   #12
dohcem1's Avatar
ok thanks
Old 01-22-2010, 02:11 PM   #13
SniperRCivic's Avatar
Quote:
in my haynes book it says with the engine off and the throttle valve fully closed it should read 0.5 and with the throttle fully opened it should read 4.5
SniperRCivic is offline   Reply With Quote
93 civic gsr swap TPS issue ThatOne02Accord Hybrid / Engine Swaps 0 01-20-2015 03:08 PM
2003 Honda Accord Throttle Position Sensor (TPS) jjknott82 Honda Accord & Crosstour (2003 - Current) 2 12-22-2014 01:04 PM
1991 accord lx TPS specs? portlandkidd157 Honda Accord (1990 - 2002) 1 03-15-2011 08:18 PM
problem with new 70mm throttle body and tps sensor 92prelude23 Honda Prelude 1 01-26-2009 06:43 PM
Question about flucuating Volatages groundedcivic91 Tech / Misc 5 02-01-2005 04:37 PM
Tags
12, 90, accord, honda, location, position, prelude, sensor, source, test, testing, throttle, tps, volt, volts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
