tools for changing flywheel/clutch ( ring gear holder, or crank pulley wrench?)
Old 11-06-2002, 04:51 PM
Dan GSR's Avatar
Default tools for changing flywheel/clutch ( ring gear holder, or crank pulley wrench?)
you guys may know better since you do more engine work
Can I use the moroso crank pully wrench to hold the flywheel from spinning when I torque down the bolts? Any possibility that it can mess up the timing?
I know I can just buy the Ring Gear Holder from Acura, its about the same price as the crank pulley wrench...but if i buy the crank pulley wrench I can use it for other things
Right tools for the job....thats my thinking
So can I just use the crank pulley wrench??
Old 11-06-2002, 08:35 PM
CunninLynguist's Avatar
Default Re: tools for changing flywheel/clutch (Dan GSR)
i dont know if that can be used...yet i do not think that would effect your timeing in any way....
Old 11-13-2002, 06:30 PM
Smashback's Avatar
Won't mess up the timing, but the flywheel bolts don't take much tq. I put a screwdriver thru one of the holes in the flywheel while I did the bolts
Old 11-13-2002, 07:33 PM
tinkerbell's Avatar
Default Re: tools for changing flywheel/clutch (Hatchblack)
??? - 70 to 80 ft/lbs is a fair bit of torque matey!
of course you can use hte crank pully wrench to hold the fly wheel still, but you better have 10ft arms or some other dude holding it!
or you can make your own ring-gear holder with a 12in x 1in piece of flat steel plate with holes drilled in each end.
one end attached to one of the pressure-plate bolts the other attaches to a bolt through hte gearbox mount holes...
(hard to picture, but works for me!)
t..
Old 11-13-2002, 08:30 PM
Dan GSR's Avatar
well i ordered a Ring Gear Holder from Acura
didn't have any in the US....so I'm getting one from Japan...should be here Friday..
JDM Ring Gear Holder .....lol....
Old 04-02-2005, 06:01 AM
mr. carpenter's Avatar
i just did this
Old 04-02-2005, 06:55 AM
743power's Avatar
Dan, do you have the part # for the ring gear holder?
Old 04-02-2005, 04:57 PM
88ED8's Avatar
Default Re: tools for changing flywheel/clutch (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">i just did this
Thats what I did
Old 04-04-2005, 04:29 AM
drumking15's Avatar
screwdriver thur flywheel bolt hole has worked fine for me for the last 4-5 clutch/flywheel combos ive done....also make sure you put a lil bit fo high temp loctite on them so they dont come loose
kr
10-22-2005 04:01 PM
smash fascism
11-12-2004 08:40 PM
H22Chameleonaccord
01-14-2003 02:17 PM
Silude
06-06-2001 07:24 PM
Quick Reply: tools for changing flywheel/clutch ( ring gear holder, or crank pulley wrench?)
