? for those that have ITR rear LCAs on an EG
Old 12-22-2001, 05:29 PM
Jimmy L's Avatar
Default ? for those that have ITR rear LCAs on an EG
What sway bar did you use? Does the factory ITR bar work?
Old 12-22-2001, 07:25 PM
eg6ajk's Avatar
Default Re: ? for those that have ITR rear LCAs on an EG (Jimmy L)
sure, JDM LCAs or ITR will work with the ITR sway bar....had it on my EF, now have it on my EG....
you can use the ITR bar with USDM LCAs as well (longest they have provisions for the sway bar)....
since the endlinks are all the same...mounts points do not change, why would there be a difference
Old 12-23-2001, 07:54 AM
chiangm's Avatar
Here is a pic of mine. They were already installed when I bought it.
Old 12-24-2001, 09:53 AM
blowncivichb's Avatar
Default Re: ? for those that have ITR rear LCAs on an EG (chiangm)
What sway bar mounts and bushings are those????
Old 12-27-2001, 05:41 AM
Default Re: ? for those that have ITR rear LCAs on an EG (blowncivichb)
Anyone else know? I'm trying to find out what parts I need to complete this:
'92 Civic H/B Si
ITR LCA's
GSR rear sway bar
Thanks. Tom
Old 12-27-2001, 09:35 AM
Jimmy L's Avatar
Ok I should have searched this one more before I asked but here's one of the treads that helped me out:
https://honda-tech.com/zerothread?id=70453
I'm going to get the beaks kit, Fastbrakes has them. That thread has just about everything you need to know. Thanks guys.
Old 12-27-2001, 09:49 AM
Thanks. Only one thing, Will the beaks kit work the same for a GSR sway bar instead of the ITR one. I'm asking 'cause that's what I already have.
Thanks. Tom
Old 12-27-2001, 10:04 AM
Jimmy L's Avatar
If your using the GSR bar I think you'll be safe using the factory brackets. You need something like the Beaks kit for the bigger bars that will tear the subframe (ITR).
Old 12-29-2001, 12:21 PM
ESCALVANTE's Avatar
JimmyL: Sell that crappy GSR bar and save up for the ITR bar. It's well worth it... believe me. The ITR bar will make your car lean a lot less and feel a lot more solid.
One more thing, I'm using the Beaks kit and the Prothane kit for added protection.
[Modified by ESCALVANTE, 11:18 AM 12/30/2001]
Old 12-29-2001, 04:22 PM
I said I don't want a title!
Todd00's Avatar
If you do the ITR rear swaybar, I HIGHLY recommend having some kind of front swaybar on too. If not, just having a huge 22mm rear bar will make a dangerous car on the street because it will swap ends with little warning.
dj theoretic
Suspension & Brakes
12-17-2008 05:35 AM
JMelt4
Suspension & Brakes
06-18-2007 10:36 AM
phatcivic99
11-27-2003 07:03 AM
abolish415
10-03-2003 12:08 PM
Spinnz
06-23-2003 08:41 PM
Quick Reply: ? for those that have ITR rear LCAs on an EG
