Z6 head, y8 intake and z6 throttle body need help with a hose
Old 08-02-2021, 04:41 PM
Sleepy Drifter's Avatar
Default Z6 head, y8 intake and z6 throttle body need help with a hose
Not sure where to route this hose. I知 pretty sure it痴 the fast idle control valve but I知 not sure. Thanks I知 advance
Old 08-02-2021, 07:36 PM
JRCivic1's Avatar
Default Re: Z6 head, y8 intake and z6 throttle body need help with a hose
That is the coolant circuit for the FITV (Fast Idle Thermo Valve). In your photo, the hose on the left goes to the IACV (Idle Air Control Valve) mounted to the back of the intake manifold, and the hose on the right goes to either a male fitting on the thermostat housing/intake manifold OR to the upper radiator hose neck on the front right corner of the cylinder head.
If you live in a Southern part of the US, connecting this isn't really necessary. It is critical for colder/Northern climates.
StuckInTexas
02-12-2015 10:38 PM
foam
11-15-2006 01:06 PM
zeekekciv
08-10-2006 04:01 AM
spun Vtec
01-31-2003 08:42 AM
Quick Reply: Z6 head, y8 intake and z6 throttle body need help with a hose
