Rwd F20c into Prelude swap in process. - Honda-Tech
Old 03-04-2017, 08:13 AM   #1
PreludeS2000's Avatar
Default Rwd F20c into Prelude swap in process.
Hi there
Just wanted to tell you guys about the swap i am doing, I took the F20B fwd swap out and i am swapping a F20C engine from an s2000 into a 5.gen prelude. I am converting it to rwd. I got the swap from the UK and have been collecting stuff for the swap.
I am using a transmission tunnel from a Subaru Legacy,
Here are some picks.
The subaru trans tunnel
Making a custom loom for the stand alone ecu.
Taking the F20B out
Test fitting the F20C engine for the first time.
Fitting the gearbox after cutting the tunnel.
Using a laser to find the center lint through the car.
PreludeS2000 is offline   Reply With Quote
Old 03-04-2017, 11:23 AM   #2
tony_2018's Avatar
Default Re: Rwd F20c into Prelude swap in process.
ooh nice, keep up with the updates
tony_2018 is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
