Question Relating B18C/CRX Swap With "L" Rear Bracket
When swap a B18C into an CRX, does the "L" bracket needs to be from a '89-'91 Integra or will the "L" bracket from the ITR fit? Thanks.
Re: Question Relating B18C/CRX Swap With "L" Rear Bracket (CW-ITR)
what trans. are you useing? if you use the 94+ hydro you need to drill the two lower bolt holes for it to eccept 19mm bolts...
CW-ITR
03-08-2007 07:14 PM
Hapa88
12-19-2004 08:12 AM
gocivicgo
08-16-2003 07:19 AM
