Poor Man Type-R
Old 04-04-2006, 09:47 AM
mudvaynefan04's Avatar
Default Poor Man Type-R
So is a B18c1 block with a B16a head gain more power than a strait GSR? What is the power increase anyone have dyno numbers?
Old 04-04-2006, 09:58 AM
Shooting Star
vtecspeed1320's Avatar
Default Re: Poor Man Type-R (mudvaynefan04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mudvaynefan04 &raquo;</TD></TR><TR><TD CLASS="quote">So is a B18c1 block with a B16a head gain more power than a strait GSR? What is the power increase anyone have dyno numbers?</TD></TR></TABLE>
Im not sure if it has more power right out of the box, the b16a head lowers compression a little. but it gives the flow characteristics of a type r head, if you add some skunk2 stg 1 cams and upgrade the valvetrain you will have a slightly more aggresive engine then an itr. Now with lowering compression you can slap a turbo to it and run it that way...or get some after market pistons and rods and have better than a itr for a little less.
Old 04-04-2006, 10:51 AM
KornyCivic's Avatar
Type-R, Hype-R, just boost a GSR, LS, B16, anything, low (7 psi) in any Honda motor will smoke all NA honda's and most mustangs, cameros, vettes too.
Bang for the buck, boost what you've got! :-) (unless it's a D series, then just forget it, they're only good for "N20 experiments"
Ben
Old 04-04-2006, 05:41 PM
drift4jesus's Avatar
Default Re: Poor Man Type-R (vtecspeed1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure if it has more power right out of the box, the b16a head lowers compression a little. but it gives the flow characteristics of a type r head, if you add some skunk2 stg 1 cams and upgrade the valvetrain you will have a slightly more aggresive engine then an itr. Now with lowering compression you can slap a turbo to it and run it that way...or get some after market pistons and rods and have better than a itr for a little less.</TD></TR></TABLE>
He didn't ask if he should get a turbo or not. Of course a honda will go faster with a turbo on it. He asked which head would be better so try answering the question.
You would need to do a little bit of bowl blending to make it flow as well as a type R as they come slightly ported from the factory. The LMDs are different in the type R as well. Plus the intake valves come with undercut stems and shaved down valve faces to reduce weight and improve flow.
the comp difference with a gsr head will be .3 higher than a b16/type R
Rico
Old 04-05-2006, 06:45 AM
Default Re: Poor Man Type-R (drift4jesus)
So since i already have a b16a with a y1 tranny should i just go poorman type-r......just do some work to the head? Thanks for all the info guys
rycrkt
44
04-14-2009 09:44 PM
93sihatchy
06-08-2007 09:46 AM
blacktegmd
03-26-2005 08:11 AM
HondaCutter
08-04-2003 09:34 AM
PUSHER
05-24-2003 11:21 PM
Quick Reply: Poor Man Type-R
