Papers w/ B18c1 Swap?
New User
Re: Papers w/ B18c1 Swap? (B18CXr)
Great, that shouldn't be a problem at all. By the way, what's the easist way to tell an OBD1 gsr swap from an OBD2 swap, or an OBD1 P72 from an OBD2 P72?
Re: Papers w/ B18c1 Swap? (cheezemaster)
One of the easiest ways to tell a OBDI engine fro ma OBDII engine is to check for the CKF sensor. Th esenor itself is behind the crank pulley..but if its OBDII (96+) there wil be a wire (w/ wire loom adn a plug on the end) coming out from under the crank pulley/timing belt cover.
This is the easiest way I can think of to tell its its OBDI or II
The plug might either have 2 or 3 wires
I think the wires are blue/red, red/white, and brown if is the 3 wire. The 2 wire is the same except theres no brown wire.
It will be right at the bottom of the timing belt cover right next to the crank pulley...if it has it...Im sure you wont miss it
SingleCamMnstr
07-09-2015 07:36 PM
h22accord101
03-03-2015 12:44 PM
Aaron Cayabyab
09-05-2012 08:21 PM
