Oil Line for Ls/Vtec?? and some questions.
My friend needs some help, please help~!!
1) He got Ls/Vtec recently, GSR head on his stock bottom Ls block, He did not get an Oil Line... GSR Oil line or something, and he was wondering if that effect HP??
2)Also, he knows for sure that his VTEC is engaging at the expected points cuz he hears it engage... but he says he doesnt feel it.... like theres no pull or anyting... is there something wrong?? please help guys...
Thanks guys for your help in advance..
WiLL~
WiLL~
New User
Re: Oil Line for Ls/Vtec?? and some questions. (*****rAcEr)
??? As far as I know, you can use either oil pump as they are both physically the same size and mount into the block. As for VTEC, if he's not feeling it, something 'aint right.
Re: Oil Line for Ls/Vtec?? and some questions. (kiracura)
Well he is runnin the GSR ecu, he has a Knock Sensor installed so there is no CEL on, um. he says he is sure that he hears the VTEC engaging.. but no power felt. Is there any way to check if the Vtec is working?? Maybe an oil change will help?? any suggestions?? Thank you guys
BoldFart16
02-08-2010 12:49 PM
WAFFLES
07-20-2001 02:23 PM
