Official H2B Hood Pics Thread QSD Kit - Honda-Tech
Old 06-09-2008, 06:17 AM   #1
Default Official H2B Hood Pics Thread QSD Kit
If you are running a QSD H2B kit in your EG, DC, EK, or EF please post pics of your car with the hood closed to show high you had to space it. Also please post pics with the hood open or atleast state things like intake Manifold type or Fire wall map or throttle body map. If your hood closes more than normal please state what tricks were done to make it close better.
I know that guy with the black DC with the JDM itr front was QSD and closed all the way due to the carbon fiber hood plus the Euro R Mani
Modified by CRAZY-EG9 at 2:29 PM 6/10/2008
CRAZY-EG9 is offline   Reply With Quote
Old 06-09-2008, 09:31 AM   #2
gibsanez's Avatar
Default Re: Official H2B Hood Pics Thread QSD Kit (CRAZY-EG9)
EF. Stock VC, no spacers and no TB MAP. Stock Manifold. I'm currently working on a re-worked VC with an SiR style hood.
gibsanez is offline   Reply With Quote
Old 06-09-2008, 01:12 PM   #3
Default Re: Official H2B Hood Pics Thread QSD Kit (gibsanez)
Quote:
Nicely done cause EF's need way too much clearance, anyone else.
Old 06-09-2008, 01:36 PM   #4
I'm really 2slow
2fast4u831's Avatar
cut the hood with grinder
1" spacers.
Modified by 2fast4u831 at 10:00 AM 6/10/2008
2fast4u831 is offline   Reply With Quote
Old 06-09-2008, 02:51 PM   #5
skunked's Avatar
Default Re: Official H2B Hood Pics Thread QSD Kit (2fast4u831)
Stock manifold
MAP on T-Body
Valvecover PCV hole plugged
Valve Cover vents added
Fiber Images hood (does not have inner hood skeleton).
skunked is offline   Reply With Quote
Old 06-09-2008, 06:02 PM   #6
SIXTY's Avatar
Default Re: Official H2B Hood Pics Thread QSD Kit (skunked)
Skunk2 IM
MAP Sensor on TB
OEM PCV
ZC Carbon fiber hood spaced 1 3/4"
Avid Mounts no trimming of underside of hood
Innovative Mounts some trimming was required to keep same hood spacing
If i really cared, even a little, im sure i could find ways to lower the hood.
SIXTY is offline   Reply With Quote
Old 06-09-2008, 09:58 PM   #7
88ED8's Avatar
Default Re: SIXTY
What do you think would give a 88-91 owner more clearance; a zc or a sir style hood???
I'm thinking a sir... though the zc looks like it may help with the cam gear clearance.....
Anybody have some CHEAP, stock hood hinges for a CRX???????
88ED8 is offline   Reply With Quote
Old 06-10-2008, 03:04 AM   #8
gibsanez's Avatar
Default Re: SIXTY (88ED8)
Even with my SiR CF hood and modified VC, I still have to run shims because of the cam gears. I completely cut off the ca gear cover from the VC.
How about an SiR style hood with a ZC bump?
Old 06-10-2008, 02:26 PM   #9
Looks like Carbon Hoods Fiber help a little
Old 06-11-2008, 08:23 AM   #10
AllMotorRandy's Avatar
Default Re: (CRAZY-EG9)
1.5" spacers, uncut VIS CF hood. Like mentioned above...... with a little more work on trimming the hood (and if it mattered ) i'm sure i would be able to get the hood to close a little more.
btw.... did you get my email?
AllMotorRandy is offline   Reply With Quote
Old 06-11-2008, 09:53 PM   #11
Default Re: (AllMotorRandy)
Yeah I'm woking on it now. You never gave me a shipping price to 11422
Old 06-12-2008, 04:17 AM   #12
jdm_ef9's Avatar
Im runnin 2" spacers with my SiR metal hood. I had to cut the webbing a little to clear the vc and map but other than that...
jdm_ef9 is offline   Reply With Quote
Old 06-14-2008, 05:00 PM   #13
dohcem1's Avatar
Default Re: (jdm_ef9)
nice trying to finish my coupe soon
dohcem1 is offline   Reply With Quote
Old 06-14-2008, 07:06 PM   #14
rebo0t's Avatar
Good thread, maybe even pictures of the frame rail area around the crank pulley would be nice.
rebo0t is offline   Reply With Quote
Old 06-16-2008, 04:01 PM   #15
Ditto
RotiEatter's Avatar
Ill have to get a good picture of mine up.
This post was just to put this in my watched topics and remind me.
RotiEatter is offline   Reply With Quote
Old 06-18-2008, 08:31 PM   #16
Linh.'s Avatar
Default Re: (rebo0t)
Quote:
i would like to see this also
Linh. is offline   Reply With Quote
Old 06-18-2008, 09:15 PM   #17
fast2camciv's Avatar
i want to see more dc2's or db's preferably ways that people have gotten there hoods to close all the way...
fast2camciv is offline   Reply With Quote
Old 06-25-2008, 06:18 AM   #18
bump
Old 06-30-2008, 10:55 AM   #19
HeikDiesel's Avatar
HeikDiesel is offline   Reply With Quote
Old 07-05-2008, 10:05 PM   #20
Dxavier125's Avatar
nice i wanna see more egs....i will post mine as well as soon as its done.........ive seen cars with h2b with their hood completely closed does anyone know wat kit they are using or if they are using a kit at all?
Dxavier125 is offline   Reply With Quote
Old 07-07-2008, 09:59 AM   #21
HeikDiesel's Avatar
Default Re: (Dxavier125)
Quote:
Evo kit sits the engine lower
Old 07-07-2008, 10:52 AM   #22
Dxavier125's Avatar
Default Re: (HeikDiesel)
yea but the ground clearance is bad.....i heard the qsd kit even tho it props the motor upwards more its a better kit because it sits better in the bay as if it was meant to be there, like at a better level....this is wat i heard im not sure
Old 07-09-2008, 05:32 PM   #23
civiceg94's Avatar
ill be posting pixs soon if someone can help me figure out why my rear tranny bracket isnt reaching the transmission.i got both side mounts mounted. the two bolts on the bottom of the tranny bracket arent reaching. but the one on top its bolted up on the plate. and this is going into my ek hatch 99. i know theirs not much pictures on honda-tech of qsd ek hatchs out there help me out so you could learn more about it and the ground clearance also thanks for any help
civiceg94 is offline   Reply With Quote
Old 07-09-2008, 07:41 PM   #24
Linh.'s Avatar
Default Re: (civiceg94)
try asking in the h2b discussion thread.
Old 07-24-2008, 03:27 PM   #25
Rav
Rav's Avatar
anyone know where the qsd kit is available i still need one for my eg hatch
Rav is offline   Reply With Quote
WTB H2B qsd Kit deucedeuceEK Want to Buy 0 12-13-2010 11:47 PM
Used QSD H2B Kit For EG/DC $550 1fastsol Northern California (Sales) 2 05-11-2010 01:42 AM
WTB H2B Part. Clutch Axles QSD Flywhell sciamutanna Want to Buy 7 10-11-2009 04:03 AM
What is The cheapest and best site to get the alternator relocation bracket for H2B CRAZY-EG9 Hybrid / Engine Swaps 8 04-04-2008 03:36 PM
Im about to go by my H22 today for my H2B but friends are begging me to buy a H23vtec Bluetop CRAZY-EG9 All Motor / Naturally Aspirated 17 03-29-2008 09:32 AM
Tags
carbon, civiccrx, ef, fiber, fs, h2b, higher, hondatech, hood, integra, kit, pictures, price, qsd, sits
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
