Rough idle B series.
Old 10-23-2012, 10:53 AM
skaraider's Avatar
Default Rough idle B series.
car info
94 Civic
B17 gsr motor
Hydro trans
Turbo
I have really rough idle after the car warms up, infact it won't idle at all after its warm only when its cool.
So here is what I have done.
Took the IACV off cleaned it out everything seems to be fine,
Took the Throttle body off cleaned out all the ports
Took the other valve on the Throttle body off and tightened the big plastic screw on the inside.
Ran fine for a few days then the idle problem started back,
Currerntly I have the Throttle body off the car.
What else am I missing?
Old 10-23-2012, 12:50 PM
EFinAwesome's Avatar
Default Re: Rough idle B series.
the other valve is the FITV. If you tightened it and it ran fine for a couple days I'd assume it came loose again. Tighten it ip again and secure it or....
https://honda-tech.com/forums/acura-integra-6/bypassing-iacv-fitv-coolant-lines-2949982/
Old 10-23-2012, 03:40 PM
skaraider's Avatar
So if i tighten it all the way down..... and secure it, does it need to be all tight? or? just slightly, or if i block it off... can i just loop the coolant lines? I checked the thread but i didn't see where it said for the lines to go.
Old 10-23-2012, 05:46 PM
hybridmiklo's Avatar
is it tuned?
Old 10-24-2012, 02:24 PM
skaraider's Avatar
yes
Old 10-24-2012, 02:33 PM
lude72's Avatar
do away with it and retune
Old 10-24-2012, 05:46 PM
skaraider's Avatar
easier said than done, nearest tuner is 3hrs away
Iloveyourhonda92
04-11-2015 07:46 PM
twentyhurtz
12-05-2008 07:30 PM
neldogg
11-17-2007 03:52 PM
afterburners
05-09-2004 04:37 AM
FourthGenHatch
04-29-2002 11:08 AM
Quick Reply: Rough idle B series.
