OBD2 LS Motor, OBD1 Honda Del Sol.. what do i need for swap?
Old 03-21-2004, 05:01 PM
jaydmej1's Avatar
Default OBD2 LS Motor, OBD1 Honda Del Sol.. what do i need for swap?
i have and OBD2 LS Motor and an OBD1 Honda Del Sol. What parts will i need to do this swap? if u know please do tell me... thanks
Old 03-22-2004, 04:47 AM
VTECVillain's Avatar
Default Re: OBD2 LS Motor, OBD1 Honda Del Sol.. what do i need for swap? (wallasol)
If you have a complete OBD2 swap including the USDM OBD2 harness, all you will need is an OBD1 P74 ECU and it will make the swap basically plug and play.
Old 03-22-2004, 09:09 AM
jaydmej1's Avatar
Default Re: OBD2 LS Motor, OBD1 Honda Del Sol.. what do i need for swap? (VTECVillain)
so basically i'll need....
OBD2 distributor
OBD2 injectors
OBD2 alternator
OBD2 ecu
OBD2 wiring engine harness (is an obd2 itr wiring harness okie?)
Engine mounts
and an obd1 ecu
what else am i missing?
keep in mind that i have 1996 b18b LS block and i'm trying to get that into an 1994 honda del sol si
thanks
Modified by wallasol at 1:48 PM 3/25/2004
EG_SINZ
14
12-12-2011 03:23 PM
fromthesun_93
08-31-2011 05:07 PM
MadCoder
07-18-2011 05:42 PM
azndelseoul3
10
06-18-2004 09:27 AM
ddong2lee
07-22-2003 06:03 AM
Quick Reply: OBD2 LS Motor, OBD1 Honda Del Sol.. what do i need for swap?
