OBD2 Distributor on my OBD1 B18C??
Old 06-12-2012, 03:25 AM
turbodcxbro's Avatar
Default OBD2 Distributor on my OBD1 B18C??
Sup fellas, I've almost got my brothers hatch running but I'm stuck..
He was running an AEM ems on the car, I've went back to an OBD1 Chipped P72. Long story short, he was somehow running an OBD2 dizzy with an MSD cap and external coil, I've swapped everything back to OEM with a new oem coil and put it back in the cap.
The harness had the dizzy plug cut off so I'm attempting to wire the mating plug from a 98 Integra onto it and use the OBD2 dizzy but I'm getting conflicting info on wire colors and such, all I'm getting is backfiring and popping when trying to start the car. Timing is set and verified.
Can I do this or do I need a OBD1 B18C Dizzy?
Old 06-12-2012, 05:58 AM
Seagull Management
94EG8's Avatar
Default Re: OBD2 Distributor on my OBD1 B18C??
OBD1 and OBD2 D and B-series distributors are identical other than the plug(s). So yes you can use it.
Old 06-12-2012, 06:09 AM
Thanks for replying 94EG8, I've read a few of your threads/posts on this subject. Problem is my wire colors don't seem to match anything you or anyone else posted...
My engine harness is OBD1 and had the dist plug cut off, and I have no idea what my distributor came off of. It was in my bro's box of parts. It fits my '00 ITR head is all I know.
Old 06-12-2012, 08:27 AM
Seagull Management
94EG8's Avatar
You want to post some pics and I'll see if I can match up the colors?
Old 06-12-2012, 09:07 AM
Will do this eve as soon as I get home, thanks bro!
baldeagle432
09-18-2009 09:53 PM
lVlemphizStylez
02-16-2007 07:15 AM
speedrcr24
02-27-2005 07:16 PM
mtber
07-14-2003 08:05 PM
Quick Reply: OBD2 Distributor on my OBD1 B18C??
