obd1 h22 into a obd2 ek??
Old 04-11-2003, 03:50 PM
h22dx's Avatar
Default obd1 h22 into a obd2 ek??
is it a pain in the ***? should i just get the obd2 h22? what will i need to do it?
Old 04-11-2003, 04:54 PM
2trix's Avatar
Default Re: obd1 h22 into a obd2 ek?? (h22dx)
yes it is a pain in the ***! and do some searching for what youll need....
Old 04-11-2003, 08:51 PM
S14HybridHatch's Avatar
Default Re: obd1 h22 into a obd2 ek?? (2trix)
its not a pain in the ***...i have it done. it was actually quite simple.
Old 04-11-2003, 11:49 PM
H22EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2trix &raquo;</TD></TR><TR><TD CLASS="quote">yes it is a pain in the ***! and do some searching for what youll need....</TD></TR></TABLE>
It is not a pain in the *** at all, disreguard his comment, I have done it several times and it IS NOT A PAIN IN THE ***!
Old 04-12-2003, 11:30 AM
MPower332TI's Avatar
Default Re: obd1 h22 into a obd2 ek?? (H22EK)
NO pain in the ***. Its the same as changing any motor in any car to obd1. Obd1 is the way to go IMO. Heres my old motor.
Old 04-12-2003, 03:53 PM
2trix's Avatar
Default Re: obd1 h22 into a obd2 ek?? (jDmDxTuRd)
ok let me clarify...an obd2 h22 into an ek is cake...and obd1 h22 with obd1 ecu and jumper is cake...an obd1 h22 into ek with obd2 ecu is a pain in the ***!
Old 04-12-2003, 05:44 PM
nah, its not a pain in the ***
its very simple
Old 04-13-2003, 09:45 AM
yaya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2trix &raquo;</TD></TR><TR><TD CLASS="quote">ok let me clarify...an obd2 h22 into an ek is cake...and obd1 h22 with obd1 ecu and jumper is cake...an obd1 h22 into ek with obd2 ecu is a pain in the ***!</TD></TR></TABLE>
haha get an obd1 ecu dork
Old 04-13-2003, 09:58 AM
h22dx's Avatar
Default Re: obd1 h22 into a obd2 ek?? (yayaRl337)
should i just get the jumper then? how much and which one should i get?
Old 04-13-2003, 01:38 PM
New User
Newman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2trix &raquo;</TD></TR><TR><TD CLASS="quote">ok let me clarify...an obd2 h22 into an ek is cake...and obd1 h22 with obd1 ecu and jumper is cake</TD></TR></TABLE>
To clarify even further, the wiring can be "cake" when you have both wiring diagrams and all you do it just match the OBD-1 plugs w/wires to the OBD-2 Civic harness. That'll solve 90% of your wiring right there but if you have little to no experience in wiring or following schematics, then it's best to leave it for someone to do it for you. When you convert to OBD-1, you are using less sensors than what your OBD-2 harness & ECU used and looked for so there will be less wiring to do and less trouble shooting to figure out in the end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22dx &raquo;</TD></TR><TR><TD CLASS="quote">should i just get the jumper then? how much and which one should i get?</TD></TR></TABLE>
We carry these:
PM me or email me for more details.
R.GroomsH22
01-21-2013 09:06 PM
eliteek
04-25-2011 01:20 PM
JDMDC4life
01-16-2008 08:36 PM
BigBlockCRX
08-28-2002 03:25 PM
Quick Reply: obd1 h22 into a obd2 ek??
