o2 Sensor and Knock Sensor
Ok I put on my o2 sensor yesterday and my check engine light went out. I have a p72 gsr ecu...now i know the ecu looks for a knock sensor but i never got a check engine light for not having one...so yesterday when i put the o2 sensor in the check engine light for the o2 went out...after driving for a few minutes the light came back on with o2 and knock sensor...would the knock sensor throw off the o2? The other thing is that as I am driving the check engine light goes away and comes back after a few minutes...any ideas?
Re: o2 Sensor and Knock Sensor (incognitoracerr)
Knock sensor won't throw a code for the o2. As for the light coming on and off, I think it's due to the o2 code, you may have a vacuum leak which cause the o2 to send a lean signal to the ecu which it can't correct then you step on the gas, the o2 voltage switches again and the light turns off.
skuba
Engine Management and Tuning
01-18-2010 05:45 PM
etherspeed
Honda Civic (2001 - 2005)
06-09-2008 06:06 AM
