no oil light after replacing oil pump
My oil light is still on. I just replaced my gsr oil pump with a type-r one. I cleaned my oil pickup and my oil pan is free of dents. There is no v-tec so its obvious its the oil pressure. Im not losing oil either, the oil level is fine. If my vtec isnt hitting wouldnt I throw a cel code 22? Im just wandering what else in the engine has to do with oil pressure? Any help is appreciated.
Re: no oil light after replacing oil pump (Miracle_X_Bar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle_X_Bar »</TD></TR><TR><TD CLASS="quote">your oil light or check engine light??? could just be a sensor...let me know more info...</TD></TR></TABLE>
well i doubt its the sensor since my vtec isnt hitting, but ill check that this weekend. and im talking about my oil light not cel.
Re: no oil light after replacing oil pump (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker »</TD></TR><TR><TD CLASS="quote">Its the oil pressure sending unit most likelly. If your light is on the vtec won't work.</TD></TR></TABLE>
isnt there a "vtec oil pressure " sensor? i think so.. check that too..
Re: no oil light after replacing oil pump (hondaZvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">
isnt there a "vtec oil pressure " sensor? i think so.. check that too.. </TD></TR></TABLE>
word....
word....
I thought the oil pressure sending unit is not connected to the ecu? Good or bad unit I should have vtec with the right oil pressure?
Re: no oil light after replacing oil pump (Si_KiMo)
Grab a pressure gauge and T it to the oil pressure sending unit. If I remember correctly, you should have at least 5 psi at idle, and a minimum of 40 psi above 2,000 RPM.
Londo2557
11-28-2016 07:27 AM
