needing help b20swap
Okay I'll start like this I have already started my Jdm b20b non vtec swap on my 98 Honda civic basicly all that's done is motor and trans is mounted and axels an linkages are in an hooked up what wiring harness would I need to use I don't have factory
Re: needing help b20swap
You might have to unwrap and reroute a couple of things, and the vtec wiring will be just hanging if you use a Y8 harness, but for the most part it should fit pretty close. Just make sure nothing is stretched or strained, and try to make it so that the harness doesn't touch anything (hoses, block, etc), just like the factory one does. You'll figure it out as soon as you start routing it around on the new motor.
CodyGt3076r
19
09-27-2012 12:53 PM
