need wiring diagrams
need wiring diagrams to a 93 dx civic & 98 ex civic.
we are dropping a 98 ex motor into a 93 dx civic... need to find those diagrams so that we can figure out what goes where because of the computer type change
Re: need wiring diagrams (terrible01)
you should be able to swap over all of your 93' OBD1 DX electronical parts (distributor, injectors, alternator, ecu) over to the D16Y8/EX motor and still retain OBD1, all you need to run is a P28 ecu and all should work fine n' dandy, unless you're doing something extraordinary.
[Modified by Katman, 11:00 AM 9/19/2002]
happy to say that the car is running as of today!!
only thing i had to change out/keep from the old motor was the alternator, it was a little different. oh...and the trottle cable had some difficulties w/ its bracket b/c he used a civic si's intake manifold.
