Need Vtec wiring diagram - Honda-Tech
Old 08-01-2006, 01:03 PM   #1
GsrBrideteg's Avatar
Default Need Vtec wiring diagram
if anyone has a link with pics, a frined of mine is using a ls engine harness on his gsr motor & needs a diagram showing where the wires have to be run under the hood for vtec
GsrBrideteg is offline   Reply With Quote
Old 08-02-2006, 12:43 AM   #2
Slopoke's Avatar
Default Re: Need Vtec wiring diagram (GsrBrideteg)
Searching "wiring vtec" found me this:
http://www.honda-tech.com/zerothread?id=1650793
Amazing!
Slopoke is offline   Reply With Quote
Old 08-02-2006, 02:42 AM   #3
Technical Hero
HondaPartsHero's Avatar
Default Re: Need Vtec wiring diagram (Slopoke)
HondaPartsHero is offline   Reply With Quote
Old 08-02-2006, 10:45 AM   #4
thanks guys I just need to wire Vtec from engine harness to Vtec seloniod, so if anyone has a link to that
Old 08-02-2006, 01:35 PM   #5
jdmsiR20's Avatar
Default Re: (GsrBrideteg)
Quote:
find the color of the wire at the ecu, and then link it back to the engine harness.
engine harness -----> vtec solenoid
done deal
jdmsiR20 is offline   Reply With Quote
Old 08-03-2006, 11:34 AM   #6
Slopoke's Avatar
Old 03-11-2015, 07:56 PM   #7
Post Re: Need Vtec wiring diagram
I'm having a vtec issue on my 01 Honda prelude h22a4 engine. It was working fine. I pulled my dash out. I left my cluster gauges hooked up and it won't work right. Anyone know of wiring back there that I may have unplugged or something? Or have a diagram I can follow. I can't find onE anywhere fo. My car all I can find is for h22 in civics
jamie18r is offline   Reply With Quote
need a wiring diagram for ho2s nov1979 Acura RSX DC5 & Honda Civic EP3 0 12-25-2007 03:24 PM
taCH wiring diagram ????? JokerTypeR Honda CRX / EF Civic (1988 - 1991) 1 07-02-2005 03:36 PM
help need cluster wiring diagram 92civic_eg Honda Civic / Del Sol (1992 - 2000) 0 11-10-2004 09:55 AM
vtec controller diagrams??? evilhatch2.0 Honda Civic / Del Sol (1992 - 2000) 2 02-17-2004 04:59 PM
diagram please FAST AS Honda Civic / Del Sol (1992 - 2000) 5 01-09-2004 09:22 PM
Tags
civic, color, controller, diagram, engine, gsr, h22, h22a, honda, pre, schematics, vtec, vtech, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
