Need help, B20 vtec swap. - Honda-Tech
Old 03-14-2017, 07:15 PM   #1
Default Need help, B20 vtec swap.
I just swapped the engine in recently and wired everything properly( I assume). The trouble is it idles insanely high 4500-5000 rpms. I used a b18b1 throttle body and I removed the coolant thing underneath the throttle body. I replaced the iac with a known good one and the problem still exists. I also have a chipped p28 ecu I bought on ebay, I'm not sure if that could also be an issue. If anyone has any ideas what so ever I am clueless at this point and plead for a response to help me in the right direction. Thanks
Belial987 is offline   Reply With Quote
Old 03-14-2017, 11:01 PM   #2
Default Re: Need help, B20 vtec swap.
What did you plug the holes with when you removed the fast idle thermo valve ??? If your answer is nothing... well, there you go. To test this, remove the inlet filter tube exposing the throttle body opening, crank up the car, and while the engine is idling (really high in this case), place your finger on the hole at the lower left (about 8 o'clock) of the throttle body inlet just in front of the throttle blade. Completely covering this hole closes the thermo valve port. This should bring the car down to a normal idle immediately if the thermo valve is your ONLY problem. Other vacuum leaks may also be contributing, so further testing may be required.
JRCivic1 is offline   Reply With Quote
Old 03-15-2017, 05:19 AM   #3
Thank you very much.
Old 03-16-2017, 11:49 AM   #4
Maybe the throttle cable is to tight?
93eh2b18c1 is offline   Reply With Quote
Old 03-16-2017, 07:36 PM   #5
Quote:
Thanks for the reply. In that case I had the throttle cable disconnected. I was being very stupid by not properly deleting the fast idle thermal valve.
IDLE ISSUES! GSR swapped civic - blox intake manifold, Omni Throttle Body and new TPS import-tooner Acura Integra 2 07-03-2013 07:49 AM
anyone know the stock honda throttle body bores? skiracer8148 Honda Civic / Del Sol (1992 - 2000) 3 05-08-2007 08:01 AM
B18 swap in ek throttle body question chineseflyrice Honda Civic / Del Sol (1992 - 2000) 3 02-17-2007 06:49 PM
throttle body ??? perseverance Honda Civic / Del Sol (1992 - 2000) 8 11-26-2006 04:32 PM
Bad Throttle body an b16a CiviCVuE Honda Civic / Del Sol (1992 - 2000) 5 09-27-2005 07:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
