motor mount problem help me out asap
i jsut got home from working on my swap with my freinds and everything isnt going as planned. the rear motor mount for the ls motor isnt going in correctly. first question, having the axles already installed into the suspension, will that keep the rear mount from aligning? also if not then maybe i might jsut not have the right motor mount it seems to be a half an inch higher and short when we tried to bolt the rear mount. so in that case what motor mount should i use????? i was told to get gsr motor mounts from the 2 sides and the rear. is this what i need any help would be greatly appreciated...
the motor we are swapping is a 94 b18b motor into a 95 civic ej coupe. please help me out i am trying to get this in right and running by tommorow night...
thanks
thanks
onyx00
09-24-2004 01:00 PM
