Mini me swap: will these ARP head studs work?
Old 10-09-2002, 09:43 AM
teal_dx's Avatar
Default Mini me swap: will these ARP head studs work?
I had bought the head bolts for the D16y8 head I am puting onto my D15b7 block. they are about an inch too short. They were only 3 bucks each so no big loss. but the old stock D15b7 bolts fit perfect! Well back to the dealership where the D15b7 head bolts cost $9 bucks each
Summit sells ARP head stud kit for "honda D16 series, 10mm" for $90 bucks.
Will these fit my block or will these be an inch short on the threaded end as well?
the part no. is ARP-208-4301.
Thanks!
Old 10-09-2002, 08:19 PM
twitchm80's Avatar
Default Re: Mini me swap: will these ARP head studs work? (teal_dx)
too short go with the d15 stock oe head bolts and btw, my buddies mini-me is awsome pulls way harder than you would expect
Old 10-10-2002, 04:51 AM
teal_dx's Avatar
Default Re: Mini me swap: will these ARP head studs work? (twitchm80)
yesterday a while after this post I called ARP and got the measurements of the studs in this kit. the measurements were about the same as the D15b7 headbolts that the dealer wanted $90 for. So I went to summit and got the ARP stud kit for $90. I threaded one in the block by hand with an old d15b7 head bolt in the hole beside it, and the bolts & washer on both are about 2.5" from the surface of the block. after measuring, the ARP studs were slightest bit taller, about 2 9/16".
I will know for sure either today or tomorrow when I get the head on. The D16y8 head bolts were about 1" too short, if anybody needs a set of 10, brand new unopened, buy mine
Old 10-15-2002, 06:06 PM
gsrteg's Avatar
I am about to do the mini me swap. I was woundering if you had to run a oil line from the head to the block or does the oil port line up on the d15 block and d16y head?
If anyone has a p28 ecu for sell, please email me at Jesse_Gibson30@yahoo.com.
Thanks, Jesse
Old 10-15-2002, 08:11 PM
sicivic's Avatar
Default Re: Mini me swap: will these ARP head studs work? (gsrteg)
no, you don't need to run an oil line.
Old 10-16-2002, 09:09 AM
teal_dx's Avatar
just remove the oil control jet?- i think its called. when you get the head off, look at the surface of the block. there is a little bronze thing between the #2 and #3 cylinders, on the side closer to the firewall. get some needlenose pliers and pull it out. The vtec head does not need this part in place.
Old 08-15-2005, 06:37 PM
dcp48's Avatar
how did this project end up? did the studs work?
Old 11-28-2005, 05:00 PM
teal_dx's Avatar
Default Re: Mini me swap: will these ARP head studs work? (95ex-t)
wow this is old, but since you asked 3 yrs later its never too late for me to answer
The ARP studs worked except for the 2 bolts in the back corners of the head. I had to use 2 of the D16y8 head bolts there.
No problems since, I beat the hell out of the car daily and started auto-xing in it this year. I did this swap @ 135k mi and have 170k now. I love this setup, I have gathered all the parts to convert to 5 speed so it will only get better
bow tie
10-21-2008 12:03 PM
h22squeaker
04-04-2005 08:20 AM
civcexcoupeblack
03-23-2003 01:22 PM
rambler
08-13-2002 03:01 PM
Quick Reply: Mini me swap: will these ARP head studs work?
