ls swap in 97 civic hx
Old 03-27-2006, 07:55 PM
dungeonKing's Avatar
Default ls swap in 97 civic hx
A friend of mine has installed a B18B in place of the single cam. The engine is out of a 92 integra. The ecu and distributor are out of a 97 integra.
The swap went great, the car starts and idols fine. The problem is when you try to rev the car it wants to bog down, and won't go anywhere.
I know it is a mess, but i am just trying to help a brutha out.
Any info is greatly appreciated!!!
Old 04-02-2006, 09:06 PM
bump
Old 04-02-2006, 09:14 PM
hatchi's Avatar
Default Re: ls swap in 97 civic hx (stifflerEG)
any Cel??
Old 04-03-2006, 08:34 AM
EKlscoupe_98's Avatar
does it only go to 4 on the rpms
Old 04-03-2006, 03:53 PM
if you rev it slow enough it would just barely make it there. kind of sounds like lack of fuel, but i really don't think that's the problem...
Old 04-04-2006, 08:57 AM
bump
Old 04-04-2006, 03:39 PM
bump again
Old 04-11-2006, 08:36 AM
you need to get a jumper harness that was what was wrong with mine an it was doing the same thing
Old 04-12-2006, 12:21 PM
bump
Old 04-12-2006, 12:31 PM
slo97coupe's Avatar
map and tps backwards?
Old 04-12-2006, 12:39 PM
schardbody's Avatar
check the map sensor connection as well, the hx probably had a TB mounted map, and depending on which TB he used it might not have been, so it could have gotten forgotten or not plugged in.
Old 04-14-2006, 11:43 AM
bump
Old 04-14-2006, 12:11 PM
92hatchling's Avatar
Default Re: (stifflerEG)
did you mess with the timing
Old 04-14-2006, 09:41 PM
timing is perfect
Old 09-12-2012, 04:59 PM
looseOFFboost's Avatar
So what happened? having the same issue.
Old 09-17-2012, 08:57 PM
bump
bakrdkng
01-22-2014 07:54 AM
Ek9 Kid
06-09-2010 06:49 PM
grannyEK
07-27-2009 12:13 PM
sweet
03-18-2009 07:58 AM
gfunkmos37
Northern California (Sales)
12-07-2008 10:32 PM
Quick Reply: ls swap in 97 civic hx
