LS and GSR axles interchangeable?? abs non-abs.. whats the difference???
Old 09-20-2003, 11:53 AM
arsenaldragster's Avatar
Default LS and GSR axles interchangeable?? abs non-abs.. whats the difference???
94 Integras.. will GSR abs axles fit on an LS with abs?? what is the different between the abs and non-abs axles?? please help!!! TIA
Old 09-20-2003, 01:01 PM
inspyral's Avatar
ABS axles have the ABS rings on the hub end with those teeth for the ABS sensors. Non-ABS and ABS axles will interchange, but if you put a non-ABS axle into an ABS car, your ABS will not function properly.
Old 04-14-2005, 07:27 AM
Fuster_Cluck's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">ABS axles have the ABS rings on the hub end with those teeth for the ABS sensors. Non-ABS and ABS axles will interchange, but if you put a non-ABS axle into an ABS car, your ABS will not function properly.</TD></TR></TABLE>
So, these ABS rings will be dead weight on a car w/o ABS? Still no problem going either route?
While we're talking about interchangeable parts between LS / GSR....
Will Eagle rods for a GSR work on a LS?
OEM water pump for a GSR work on a LS?
Thanks!
Old 04-20-2005, 08:13 PM
j0nptw's Avatar
Default Re: (Hybrid93Hatch)
sorry but back to the axles......... if i have ABS in my 94' EX and i'm swapping in a B18C, can i buy non-ABS B series axles and then take the ABS ring off my civic axles and put it on the B series ones? I've heard you can do this but i'm not sure and i want to be positive before i buy any.
Old 04-21-2005, 04:10 PM
j0nptw's Avatar
Default Re: (j0nptw)
bump
Old 04-24-2005, 08:52 PM
j0nptw's Avatar
bump... anyone know about this???
Old 04-24-2005, 10:49 PM
mckenzie's Avatar
h20 pump should work.. all those lsvtec guys run itr and gsr h20 pumps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks!</TD></TR></TABLE>
bob441
11-11-2015 06:50 PM
realis9
05-30-2008 12:55 AM
204hatch
04-04-2008 09:11 AM
shortycm17
12-26-2007 03:31 PM
charjacq
03-02-2003 09:21 AM
Quick Reply: LS and GSR axles interchangeable?? abs non-abs.. whats the difference???
