JDM d15b-d16z6 parts compatibility
Old 02-08-2004, 02:06 PM
toonces's Avatar
Default JDM d15b-d16z6 parts compatibility
I'm going to be swaping a Jdm d15b into my 95 ex coupe and I was just curious what parts (engine) are swapable between the two motors. Example: I'm gonna want want to replace the water pump and timing belt on the d15b before I put it in can I use the parts off of my d16z6? what about tune up parts (i.e cap plugs wires etc.)?
Any help is greatly appreciated...
Old 02-09-2004, 04:57 AM
VTECVillain's Avatar
Default Re: JDM d15b-d16z6 parts compatibility (toonces)
The JDM D15B shares parts with OEM D16Z6 (Si/EX) and the D15Z1 (VX). Do some searches and I'm sure you'll find parts compatibility lists for everything you will need to know.
Old 02-21-2004, 09:50 PM
NatedoggAZ's Avatar
Bump for the man - I am doing the same swap too and that info would also benefit me - thx!
N8DOGG
Old 02-27-2004, 12:53 PM
pimp civic's Avatar
Default Re: JDM d15b-d16z6 parts compatibility (NatedoggAZ)
the cap its the same thing like d16z6 or d15b7
water pump its p08 (vx engine)
timing belt p08 (vx engine)
Old 03-04-2004, 10:19 AM
toonces's Avatar
Default Re: JDM d15b-d16z6 parts compatibility (pimp civic)
Just for a note my EX water pump fit the d15b but the timing belt did not. The VX timing belt must be used.
Old 03-04-2004, 05:55 PM
sbacchus's Avatar
i did this swap recently, the cap and plug wires will fit.
Old 04-26-2004, 10:20 AM
drewbie*'s Avatar
Default Re: JDM d15b-d16z6 parts compatibility (sbacchus)
I purchased a z6 timing belt. are you saying it wont fit? i need to get the d15z belt? i've herd those are too tight, or is that just for a mini-me swap. Let me know Thanks.
crxblues
06-17-2009 04:03 PM
hermistonkilla
17
01-10-2009 08:47 AM
jeffchaisi
09-07-2006 06:55 PM
HXMan
12-08-2004 06:57 PM
NatedoggAZ
07-26-2003 11:36 AM
Quick Reply: JDM d15b-d16z6 parts compatibility
