How to test resistor box? - Honda-Tech
Old 05-04-2004, 03:32 PM   #1
teknics1's Avatar
Default How to test resistor box?
My H22 del sol is not running right. I checked the resistance of all the injectors, they all read between 12-13ohms. Are these OBD1 or OBD2? I know I have the resistor box wired up right, just not sure if it is working correctly. How do I check it and what should the readings be?
Modified by teknics1 at 2:00 PM 5/6/2004
teknics1 is offline   Reply With Quote
Old 05-05-2004, 05:35 AM   #2
teknics1's Avatar
Default Re: How to test resistor box? (teknics1)
TTT. No one knows?
Old 05-05-2004, 12:46 PM   #3
GSR-T-'s Avatar
hmmm i would like to know too
GSR-T- is offline   Reply With Quote
Old 05-06-2004, 05:59 AM   #4
teknics1's Avatar
TTT
Old 05-06-2004, 05:17 PM   #5
EE_Chris's Avatar
You have high impedance injectors....why are you using the resistor box?
But to test the box, there will be one common wire that is internally connected to one leg of each resistor. There will also be 4 other wires which lead back to the individual resistors. Just keep one meter lead on the common wire and measure the resistance between it and the 4 individual wires.
EE_Chris is offline   Reply With Quote
Old 05-06-2004, 05:30 PM   #6
teknics1's Avatar
Default Re: How to test resistor box? (EE_Chris)
I was told that I needed to use the resistor box to run my h22 in the del sol. Was I told wrong? Thanks for the help.
Old 05-07-2004, 05:34 AM   #7
EE_Chris's Avatar
Honda ECUs want to see a total injector impedance of around 12-13 ohms. Saturated style injectors are around 12-13 ohms while the peak/hold variety are around 2-3ohms (hence the need for the resistor box which contains 4 10 ohm resistors).
Now, if the injectors you're using measure out to 12-13 ohms, as you've stated they do, then you don't need the resistor box.
usng resistor from a 6cyl on a 4cyl. chihuahuamanx Tech / Misc 3 06-07-2006 07:59 PM
Teknic Violator suits or ANY Teknic Suits????? trbo823 Honda Motorcycles 15 08-13-2005 12:09 PM
Sugar Glider owners Check-In Teknic73 General Discussion and Debate 1 02-20-2004 06:16 PM
Wiring Woes! Someone help please! teknics1 Hybrid / Engine Swaps 7 11-04-2003 07:43 PM
WTB stock p28 teknics1 For Sale 2 11-01-2003 08:41 PM
Tags
automotive, box, check, civic, crx, ef, h22, hodatech, honda, impedance, injectors, measure, resistance, resistor, resistors, test, testing, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
