ls/vtec quetsion?
Old 05-05-2004, 09:29 PM
88whitehf's Avatar
Default ls/vtec quetsion?
I was wondering if you could use the ls windage tray with the gsr girdle with the ls oil pan or do you have to run the gsr girdle windage tray and the oil pan. I would imagine that i could use the ls windage tray with the girdle. but will the girdle make the clearance??
thanks
chris
Old 05-05-2004, 09:35 PM
CompressionFed's Avatar
Default Re: ls/vtec quetsion? (88whitehf)
I have a Z10 girdle on my Ls/Vtec...I have to use a GSR/TYPE R windage tray and oil pan.
Old 05-05-2004, 10:52 PM
HyperX's Avatar
also i got a question too. i would assume that you would have to use a gsr intake pipe if you have a gsr head? correct me if i am wrong.
Old 05-05-2004, 11:45 PM
Default Re: ls/vtec quetsion? (HyperX)
Depends if its a short ram or cold air, and what car you are putting it in. For an eg, some cold airs will not line up...because the throttle body is lower on the gsr than b16-type r, etc, the angle going towards the hole in the engine bay is too much to make it work. For Integras it probably won't matter too much.
AEM has answered this problem with their hybrid intakes. (type r in EG, gsr in EG)
All short rams should work
Old 05-06-2004, 12:43 PM
HyperX's Avatar
Default Re: ls/vtec quetsion? (CompressionFed)
i have a 94 ls teg and i have a 96 gsr head. i do realize that the gsr manifold curves down and the ls manifold is SUPER tall. also i am not sure if the size of the head between the ls and gsr are the same size. (eg height) so if put that gsr head on, i am assuming that it will be pretty much like the size of a gsr motor. therefore is where i assumed i needed a gsr cai. or am i assuming wrong?
Old 05-06-2004, 08:41 PM
boostinb20vtec's Avatar
you my friend are highjacking!
93egSLEEPER
09-27-2009 07:05 PM
scspeed
07-29-2008 07:16 PM
nabin
04-05-2008 07:52 PM
xxmikexx206
01-08-2007 09:08 AM
l
07-31-2002 02:36 PM
Quick Reply: ls/vtec quetsion?
