How much to balance a B20 crank
Old 05-30-2003, 06:31 AM
whoobeedoobee's Avatar
Default How much to balance a B20 crank
Can you guys give me a ballpark for balancing a b20 crank?
Thanks
Old 05-30-2003, 12:16 PM
Default Re: How much to balance a B20 crank (whoobeedoobee)
nobody has done this?
Old 05-30-2003, 02:34 PM
madman604's Avatar
ALL honda/acura cranks are balanced very well from the factory.
Old 05-30-2003, 02:40 PM
Kamin's Avatar
Default Re: How much to balance a B20 crank (Turbo E)
yea honda cranks are usually balanced to 99.9% unless its been damaged somehow.
Old 05-30-2003, 03:13 PM
b20ek's Avatar
I had my entire bottom assembly balanced for $60.
Old 06-06-2003, 08:14 AM
The Rob's Avatar
Default Re: How much to balance a B20 crank (b20ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20ek &raquo;</TD></TR><TR><TD CLASS="quote">I had my entire bottom assembly balanced for $60.</TD></TR></TABLE>
Is that the normal going rate or did you get hooked up? That seems really cheap.
Old 06-06-2003, 03:50 PM
Trickturn's Avatar
Default Re: How much to balance a B20 crank ( Rob)
$100 for the balancing of mine
Was off a lil... now it is below a gram
Pete
Old 06-06-2003, 06:36 PM
b20ek's Avatar
Well I spent like $350 all together on machining so I guess He hooked me up for sixty on the balancing . Anyone in Dallas need machine work I can send you to a bad *** machine shop.
Old 06-06-2003, 07:16 PM
Ruby Civic's Avatar
i spent 80 for balance of the whole bottom end on my b20 complete with inclusion of clutch, flywheel, and pulley
iloveb16
08-06-2007 10:05 AM
xQB21x
01-30-2007 10:08 PM
Quick Reply: How much to balance a B20 crank
