HELP>>What spark plug wires fit a ZC DOHC engine?
Old 03-14-2006, 10:59 AM
Mike@K-Tuned's Avatar
Default HELP>>What spark plug wires fit a ZC DOHC engine?
As the topic states I'm trying to figure out which spark plug wires will fit a DOHC ZC engine properly. All the wire sets I have tried are too tall and stick up above the valve cover by about 1". I would like to use NGK wires but the correct fitting OEM wires will also do me just fine. Any links or part numbers would be very helpful. I have tried the OEM wires for an 89 Acura Integra but they just don't fit right. Help me out here guys, Thanks in advance.
Old 03-16-2006, 06:32 PM
superfly11's Avatar
Default Re: HELP>>What spark plug wires fit a ZC DOHC engine? (EGgsrAM)
try an 1991 interga wire set up it might work
Old 03-17-2006, 10:32 AM
redhondacivic's Avatar
Default Re: HELP>>What spark plug wires fit a ZC DOHC engine? (superfly11)
Since thats the car that motor came in I would try that!!
Old 03-18-2006, 09:59 PM
projectTeG's Avatar
first gen integra wires,88-89 i believe
Old 03-19-2006, 05:41 PM
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">first gen integra wires,88-89 i believe</TD></TR></TABLE>
Those are the ones. My buddy e-mailed me the same info and it is correct. 1986-1989 Integra wires fit perfectly.
Old 03-22-2006, 08:05 PM
boostedblkef's Avatar
i used 89 integra wires and they worked fine make sure the tards from the parts store didnt give you the wrong ones you can try to buy universals and cut and crimp them to lenth that you want
chase7687
10-04-2009 07:30 AM
ef_zc
14
01-27-2008 07:50 AM
JDM89CrXZc
10-22-2007 09:58 AM
therealciviczc
07-11-2003 06:16 PM
1990hondaHF
11
09-25-2002 09:45 AM
Quick Reply: HELP>>What spark plug wires fit a ZC DOHC engine?
