h22a engine codes
h22a engine codes
SO I dropped an h22a into my 99 accord. Great combination. Now I have an OBD1 ecu in an OBD2 car. I hooked my scan tool up and obviously I got squat but a linking error in the scanner. So my question is, how do I check my engine codes?
Re: (fabworxs)
Enigine lights don't blink. They are steady until you make the connection to make it blink the trouble codes. This is what I am trying to figure out. If you have a trouble code, the light isn't going to blink that code number all the time just because there's a code. The engine light is on when a code exists, I need to make it blink to figure out what the codes are.
Re: (Subwarrior)
http://www.c-speedracing.com/faq/06.php
Try reading this. If you don't know how to pull the codes than I think this will help you.
Re: (duofilm)
I already knew the wire jump trick and counting codes. What I couldn't find was where the connector was located, and the wire colors etc. That was the info I was looking for, thanks much.
Re: (v4lu3s)
Thats what I thought. I looked behind the kick panel on pass side and didnt see the one the other post said. The blue wire I have found, but the CEL doesnt do anything when I jump them.
type Gendy
04-21-2003 04:48 PM
